TRANS CHANGE AND REAR GEARS, speedometer question
Discussion in 'Transmission & Driveline Topics' started by Lou6t4gto, Jan 24, 2018.
  1. Lou6t4gto
    Lou6t4gto Veteran Member
    329
    15
    Aug 18, 2010
    Ocala, Fla
    I just changed from a th350 and 2.73 gears to a 700R and 3.42 gears. the speedometer gears are still set up for the 2.73s. (I'm waiting for a new driven gear "Housing". About How Much MPH speedometer "error" is there now ?? Until I get the gears changed Thanks
  2. camaro71/holland
    1,093
    48
    Aug 27, 2003
    The Netherlands
    Use your phone / get an app that shows you the gps speed and go for a spin.
    Dave Nelson likes this.
  3. Dave Nelson
    Dave Nelson Veteran Member
    3,855
    1,251
    Dec 19, 2003
    Vineland N.J USA
    I've used the app several times, highly accurate.
  4. Lou6t4gto
    329
    15
    Aug 18, 2010
    Ocala, Fla
    old fart, no cell phone at all !
  5. 70-camaro
    70-camaro Veteran Member
    1,944
    323
    Mar 25, 2010
    marietta ohio
  6. G72Zed
    G72Zed Veteran Member
    647
    91
    Sep 8, 2015
    Or "pre" internet days, math formula with the old pen and paper, lol, still works
    Assuming a 27 inch tall tire and not factoring in converter slip %, and a constant rpm of 2,300 for both setup's = + 10 mph
    TH350/2.73 = 68 mph
    700R4/3.42 = 78 mph (OD effective ratio of 2.38)
  7. berg2695
    berg2695 Veteran Member
    189
    23
    Nov 13, 2011
    GONE
    The only thing that matters in this case is the change in the rear gear ratio. 3.42 is 25% more than 2.73. Therefore, the speedo will read 25% higher than the actual road speed. For example: an indicated 50 is actually 40; an indicated 75 is actually 60 mph.
