Trans Am sway bars
Discussion in 'Camaro Questions' started by 70-camaro, Aug 31, 2016.
  1. 70-camaro
    70-camaro Veteran Member
    1,611
    262
    Mar 25, 2010
    marietta ohio
    Will 1-1/4 front sway bar from a 70-81 Trans Am fit my 70 Camaro? Also will the rear from a 74-81 Trans Am fit? Any help would be appreciated. Thanks
  2. Gary S
    21,324
    372
    Yes, both fit perfectly as both cars are F body and use the same parts. You will most likely have to weld on the upper frame mounts for the rear swaybar is your 70 didn't originally come with a rear swaybar. Most cars that came without a rear swaybar do not have the mounts welded on the frame to install one.
  3. Twisted_Metal
    26,042
    527
    Yes... They will fit.
    But the rear bar brackets will need to be welded to the frame as there isn't enough frame thickness to hold the bracket bolts solidly.
    (Later Camaros had a plate inside the frame for more thickness.)
  4. badazz81z28
    14,705
    166
    Las Vegas, NV
    Don't forget the right size bushings
  5. 70-camaro
    1,611
    262
    Mar 25, 2010
    marietta ohio
    Yea, I emailed him to be sure he has all of the hardware. $30 for the front and $40 for the rear,hopefully he has the hardware. Will want to buy new bushings most likely.
