TR3550 Tremec 2600708 questions....
Discussion in 'Transmission & Driveline Topics' started by Dorito724, May 3, 2017.
  1. Goodwrench1965
    Goodwrench1965 Veteran Member
    873
    23
    Apr 23, 2010
    Charlotte NC
    Here's a photo of how I modified the crossmember. I cut the crossmember and welded in flat plate to adjust the position where I needed it. The driveshaft was cut and a new joke with the right spline added and balanced.
  2. black_aerocoupe
    My experience with that has been 2 things:
    It will cause irregular wear of the flywheel ring gear and starter pinion teeth. Even at only a tenth inch thick.
    And it will alter clutch release point. Not bad with a standard diaphragm clutch. A PITA for the LT1 T56 clutch.
  3. Dorito724
    Dorito724 Veteran Member
    219
    Mar 13, 2001
    Beaver Falls, Pa
    8AAF6DC6-C9CE-48B4-8CD7-68D90EB4B5F2.jpeg Next stop into the car! WhooHoo!
