TM2R Edelbrock - any good?
Discussion in 'Engine Topic' started by gordonquixote, Jul 2, 2007.
  1. gordonquixote
    3,016
    Jul 18, 2006
    Tallahassee, FL
    TM2R Edelbrock Intake - big block - any good?
    I have the Edelbrock TM2R intake (the carb sits diagonally to the engine, I think they are called Tarantulas). Is it any good? I know it is kinda old school but seriously - how much better can an intake get.
    It is medium rise - I already picked up my steel cowl hood.
    My question is - If I went back to a low rise (stockish) intake and used my original hood - would I be missing out on much performance?
  2. muscl car
    very good intake for a BBC with retangular port heads ,it's rpm range is 4000- 7200rpm . i've got one of these intakes in my garage just waiting on a bbc to put it on !!
    the reason for the angled carb pad is for better fuel distribution
  3. gordonquixote
    3,016
    Jul 18, 2006
    Tallahassee, FL
    I have 049 heads (open chamber oval ports). Still good to go? I think stock redline is 4,800 (1972 396), but it is somewhat built. I would feel comfortable up to 5,500 rpms.
    I may have overcarbed a little (770 Holley) but I will build a 454 one of these days and then I can just swap everything over.
  4. rustbucket79
    rustbucket79 Veteran Member
    For a 5500 396 a smallish dual plane will do the trick, like a Performer O
  5. BobB
    BobB Veteran Member Lifetime Gold Member
    1,873
    May 10, 2000
    USA
    Isnt the TM2R for the rectangular port heads?
  6. muscl car
    yep !!!!
  7. 80'427
    80'427 Veteran Member
    1,886
    Jan 1, 2005
    Fairbury, NE, USA
    I am running a 1050 on the track on my 427 (438 really) so a 770 is perfect for a 396. I would run performer rpm on a oval 396 though. Oh the 427 made 20 more hp with the 1050. I use a 750 dominator on the street.
  8. TooLateVTEC
    TooLateVTEC Veteran Member
    1,451
    Dec 5, 2005
    Fredericksburg,Va
    Your killing lots of power w/ that thing oval a Perf. RPM. I'd run the Perf. RPM Air Gap if you have the hood clearance. Hot Rod did a test of intakes on BBC's and it was the best one.
  9. BobB
    1,873
    May 10, 2000
    USA
    Might be kind of a mismatch on the oval ports then.:cool:
  10. gordonquixote
    3,016
    Jul 18, 2006
    Tallahassee, FL
    Thaks guys - I have my intake in the swap meet section looking to trade someone for an oval port intake.
    G
