three piece wing template?
Discussion in 'Body Restoration' started by JOEY72camaro, Dec 19, 2017.
  1. JOEY72camaro
    JOEY72camaro New Member
    14
    May 3, 2016
    Looking for a template for 1970-73 holes for the three piece wing or the measurements?
  2. CamarosRus
    CamarosRus Veteran Member
    1/4x20 Centering studs from McMaster Carr.....or I'll sell/send you mine
    All the template hole layout is a huge waste of time...and I still got it wrong
    You do this on center section first, then install correct mounting studs and then do each end piece lining up with qtr and center section......
    There are several other threads on THIS SUBJECT with pics
    Please search....
    You wont believe how time consuming this is til you try yourself and drill incorrect holes.....the centering studs method WORKS the best, the fastest the most accurate
