Thinking about a 700R4 or maybe the 200R4
Discussion in 'Transmission & Driveline Topics' started by rocket dawg, Nov 19, 2015.
  1. rocket dawg
    rocket dawg Veteran Member
    207
    11
    May 5, 2015
    Grand Rapids Mi
    79 with turbo 350 behind a 406 SBC around 450 est hp-the trans leaks like a sieve when not in use. I was about to pull the trigger on a 700R4 but someone mentioned the 200 would not require a different drive shaft.
    If you have a 200 R4 tell me the ins/outs of it. Advantages of either.
    This winter is work time on the car, it gets an interior and quite possibly a new transmission. I like the overdrive part of it.
    3:42 gears
  2. 76z28
    76z28 Veteran Member
    1,696
    Jun 29, 2009
    bakersfield
    200r will also keep the current gearing you have, it will just have over drive.
    I would go 200r over 700.
  3. warped
    I have a 700 in the truck and it isn't a problem, but that's me. Most complain about the spread between 1st and 2nd gear, it is pretty short. The 200 is a closer match to the TH350 and will be easier to install, but the 700 isn't much more involved. There are a few things to be aware of though. 200-4r transmissions are getting harder to find and some are adding a premium to the price for that reason. both the 200 and 700 are very weak in stock form and neither will hold up behind any kind of serious power without upgrades. Take a look at Jake's site to get some info about the differences. I don't think he does the 700-r4, but GM renamed it the 4L60 later in its life. If you plan to use any of that power you will want to find a qualified shop to harden which ever transmission you choose. Good luck.
    www.jakesperformance.com
  4. Skip Fix
    Skip Fix Veteran Member
    2,007
    Mar 21, 2007
    Katy,Texas
    Be nice if someone made a 700 first gear not so low so the spread is not as great.
    Also start putting much power to the 200 and you need $$ parts in it. I have Pontiac buddies pushing 600 HP through them but cost 3K+ for tranny and convertor. Just picked one up from a friend who needed some cash form the same builder. Just look at Jake's page on 200Rs
  5. 76z28
    1,696
    Jun 29, 2009
    bakersfield
    I am going 4l80 for this reason. Plus its electronic :crazy:
  6. 80sz
    80sz Veteran Member
    2,239
    175
    Feb 2, 2014
    Buffalo,n.y.
    Different gears are available for the 700 ,think it was a 2.85 gear for first,a 350 is 2.75, stock for 700 is 3.06, then second was 1.6 ,I saw them on raptor transmissions website.
  7. 76z28
    1,696
    Jun 29, 2009
    bakersfield
    Th350 is 2.52, 1.52, 1
    TH400 2.48, 1.48, 1
    200r4 2.52, 1.52, 1, and I THINK .67
    700r4 3.06, 1.56, 1, and I THINK .7?
    4l80e 2.48, 1.48, 1, and .75
  8. 80sz
    80sz Veteran Member
    2,239
    175
    Feb 2, 2014
    Buffalo,n.y.
    Yup,thx for refresh. Think od fo 200 was .67 compared to the .70 for 700,had a 700/4.10 combo,getting traction was almost impossible. I'd like the 4l80 but to much at time,was going rate now? I went 350 and 3.70 gears,no od suks.
  9. 76z28
    1,696
    Jun 29, 2009
    bakersfield
    Yeah I just want over drive.. I know the 700 and 200 would cost more to build than the 4l80 to live behind a big block.
    my build
    1700 for rebuilt 4l80 with transgo hd-2 shift kit
    800 for converter
    690 for computer
    100 for fluid
    130 for shorten drive shaft
    and little things here and there--100
  10. olds403
    olds403 Member
    58
    Jun 11, 2004
    Austin, Tx
    The 200r4 is just like any of the above mentioned including the 700r4 are 80's trannys. All getting scarce. The 200r4 is bolt in. Parts are harder to get, but most all reproduced. Mine came from Ck performance. The tricky part is any linkage mods for a qjet or other carb for the tv cable. Rest is just a lock up relay or switch.
