Thermostat housing helicoil help
Discussion in 'Engine Topic' started by 7.62fmj, Dec 18, 2017.
  1. djorgensen3
    djorgensen3 Veteran Member
    363
    35
    Oct 15, 2009
    Peoria, Az
    The insert will be a steel insert vs just the re-tapped aluminum.
  2. accelo
    accelo New Member
    Jan 12, 2015
    washington
    Cardinal and djorgensen3 like this.
  3. 7.62fmj
    7.62fmj Veteran Member
    118
    May 16, 2017
    Jacksonville, Fl
    So to use that insert I'd use the 9/16 tap and a 33/64 drill?
    On a slightly unrelated topic, my bolts had lock washers before, but they're in bad shape. Can I use a normal washer or do I need new lock washers?
  4. djorgensen3
    363
    35
    Oct 15, 2009
    Peoria, Az
    Right on!!! I haven't seen these before but they look to be a whole lot easier and certainly a lot cheaper.
  5. 7.62fmj
    118
    May 16, 2017
    Jacksonville, Fl
    For sure, the $90 plus for the time sert kit was kind of a turn off
  6. 1980RS
    1980RS Veteran Member
    1,772
    49
    Jun 17, 2006
    MN
    Here is what we did once, put Teflon tape on the bolt threads, then get some A-B Epoxy or JB Weld fill the hole with it thread in the bolt let it dry and with the Teflon on it the bolt should come right out. Belzona works better buy is way spendy. worth a try.
  7. 7.62fmj
    118
    May 16, 2017
    Jacksonville, Fl
    Thanks all for the help. Went with the Fastenal inserts and am officially leak free.
    Cardinal likes this.
  8. Cardinal
    8,243
    13
    Jun 22, 2003
    Endicott, NY
    As daddy used to say, "nothing succeeds like success!"!
