The Z-Corn. My 80 Z28.
Discussion in 'Project Progress' started by ISRcamaro, Oct 23, 2016.
  1. 8pack
    2,446
    85
    Aug 29, 2007
    Pittsburgh, PA
    The ebrake cable runs over the exhaust but I suppose it depends on perspective...It does not run between the body and the exhaust, it runs between the exhaust and the ground.....
  2. ISRcamaro
    ISRcamaro Veteran Member
    555
    22
    Oct 10, 2016
    Israel
    They are running between the exhaust and the ground, just rubbing the exhaust from under it.
  3. 8pack
    2,446
    85
    Aug 29, 2007
    Pittsburgh, PA
    Yup....they all do...if you try to run over the top it gets too close to the driveshaft. I am sure other's have done some custom routing to get around the issue but you have it right.
    I have custom dual exhaust with an x pipe and I couldn't find a work around without welding something to the under carriage which I don't have the skills or equipment to do....
  4. ISRcamaro
    555
    22
    Oct 10, 2016
    Israel
    I'm thinking about taking piece of the aluminium (?) shower hose.
    Any idea about the Weiland? :p
  5. 8pack
    2,446
    85
    Aug 29, 2007
    Pittsburgh, PA
    No idea on the Weiand....If you are sure you are reading the number right the 8007+ is definitely for a Chrysler 318 based on everything online....they sent you the wrong one.
    You may get a rattle from that but worth a try. Just remember if there is any plastic in there it will melt. You also will need to put something on each side of the aluminum tube to keep it from floating back and forth like a cable clamp....
  6. ISRcamaro
    555
    22
    Oct 10, 2016
    Israel
    They didn't send it.
    The car came like it from last owner.
    I'll try it. Unless you have any other idea for preventing friction :D
  7. 8pack
    2,446
    85
    Aug 29, 2007
    Pittsburgh, PA
    Well, are you sure you don't have a Mopar motor in the car LOL?! Nothing on the web indicates that you can put a Mopar intake on a chevy 350......
  8. ISRcamaro
    555
    22
    Oct 10, 2016
    Israel
    I'm not sure at nothing :p
    Last owner didn't tell much
  9. ISRcamaro
    555
    22
    Oct 10, 2016
    Israel
    I'm looking for the cluster back wiring clips
    Any idea where can I find it?
    Not sure it's the part name so I marked it at the picture
  10. ISRcamaro
    555
    22
    Oct 10, 2016
    Israel
    Is anyone ever replaced is wiper washer bottle?
    I bought a new one (since I didn't had one at all). At all the vids and the pictures it installed on the left wheel house while it curved and the bottle triangle mount is flat straight. Are there any shims or special hardware I'm missing?
