TH400 without electric kickdown
Discussion in 'Transmission & Driveline Topics' started by PBZ28, Nov 4, 2017.
  1. PBZ28
    PBZ28 New Member
    17
    Nov 3, 2017
    Guess it's a trip to the junk yard! I really like the engine compartment as clean as possible too.
  2. GoldenOne7710
    GoldenOne7710 Irrelevant Member Lifetime Gold Member
    4,510
    284
    Jun 23, 2004
    Athens, GA
    Good luck. Post up some pics of whichever route you choose.
  3. hogg
    hogg Veteran Member
    3,156
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    just pull it down to 2nd when you wont to pass or down shilf put your foot in it till you wont to shift out to hy
  4. brooksman9
    brooksman9 Veteran Member
    5,982
    115
    Jun 10, 2007
    Olive Branch, MS
    Can you post a pic of what you are looking for. I might have one.
  5. Da_Raabi
    Da_Raabi Veteran Member
    1,106
    143
    Jan 19, 2011
    Daytona Beach, FL
    Yup, and I'm pretty sure the switch is the same too. I got an air induction setup off a member here, and when it arrived I realized that the pedal bracket was exactly the same and the switch was IDENTICAL to the one for the TH400 kickdown on my truck.
    I would think you could actually do both with the one switch!
  6. camaro71/holland
    1,051
    43
    Aug 27, 2003
    The Netherlands
    Th400 has a 'protection' for overrevving in Lo. You can bypass this internally in the valve body by reshaping (grinding) one of the lands on a valve.
  7. GoldenOne7710
    4,510
    284
    Jun 23, 2004
    Athens, GA
    Would a '79 have it being that they didn't start air induction hoods until 1980?
  8. junkyardZ28find
    771
    Mar 4, 2012
    des moines, iowa
    You can also use a 67-72 Chevy truck kickdown setup if you're using a q-jet...that bracket/switch mounts on the two rear carb baseplate mounting bolts.
  9. junkyardZ28find
    771
    Mar 4, 2012
    des moines, iowa
    Heres one from a 71 C20 truck I parted out awhile back for reference
  10. Lowend
    14,614
    319
    Mar 25, 1999
    San Jose, CA, USA
