TH400 without electric kickdown
Discussion in 'Transmission & Driveline Topics' started by PBZ28, Nov 4, 2017.
  1. PBZ28
    PBZ28 New Member
    17
    Nov 3, 2017
    I just got back into muscle car ownership. Haven't had one since the late sixties. I just bought a 79 Z28 with a 383 stroker, th400, quicksilver b&m, and 10 bolt 3.73 posi rearend. Car runs and drives great but the builder did not connect the electric kick down. Will it hurt to drive it this way? I always had 4 speeds back in the day. Thanks! This the best Camaro forum on the net!
  2. GoldenOne7710
    GoldenOne7710 Veteran Member Lifetime Gold Member
    4,439
    261
    Jun 23, 2004
    Athens, GA
    It won't hurt it...just not as convenient to drive. You can obtain all the necessary parts to connect it and use as designed. Not a hard job.
  3. PBZ28
    PBZ28 New Member
    17
    Nov 3, 2017
    Thanks that is good news! Which is better, using a switch off of the accelerator pedal in the car like it probably was when stock, or something like a nitrous switch hooked up to the throttle linkage at the carb? I think all I need is a ground and switched 12 volts to go to the trans? Thanks!
  4. budro6968
    budro6968 Veteran Member
    2,534
    344
    Apr 2, 2016
    Jax Florida
    Can always manually down shift if you need to.
  5. GoldenOne7710
    4,439
    261
    Jun 23, 2004
    Athens, GA
    I've seen it done both ways to be honest. Whatever is easier for you is the way I'd do it.
    PBZ28 likes this.
  6. PBZ28
    PBZ28 New Member
    17
    Nov 3, 2017
    I seem to remember that wasn't a good idea with a TH400 unless you stay on the throttle or are stopped. Or maybe I'm out in left field here!
  7. PBZ28
    PBZ28 New Member
    17
    Nov 3, 2017
    Can't find the stock parts for the pedal so it looks like a kit from B&M for the carb is my only option or fab something up.
  8. budro6968
    2,534
    344
    Apr 2, 2016
    Jax Florida
    Won't hurt anything. I did it all the time when I was young. Down shift and punch it. I would pretend I had a manual trans in Dear old Dad's 72 Cutlass. The TH 350 would stay in low for ever. The TH 400 would Shift out of low by it self at a high rpm. It would really slam second. Made the tires bark a little in my 75 454 Suburban. I talking about stock, no shift kit.
    harkz28 likes this.
  9. GoldenOne7710
    4,439
    261
    Jun 23, 2004
    Athens, GA
    Unless you comb the boneyards for cars that were factory equipped with a TH400 and get all the under dash bracketry...and possibly the switch too...from the donor car. I don't like the extra clutter around my carb...But that's just me.
    PBZ28 likes this.
  10. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    156
    11
    Oct 4, 2002
    Buffalo,NY,USA
    The bracket for the pedal switch is already there. The same one used for the Air induction hoods. Just get that switch and wire it up.
    PBZ28 likes this.
