TH 350 Accumulator removal??
Discussion in 'Transmission & Driveline Topics' started by 70-camaro, Dec 4, 2017.
  1. camaro71/holland
    968
    29
    Aug 27, 2003
    The Netherlands
    Not an expert, but have done several transmissions so far.
    You need to compress the ring like I said before and use transmission lube to hold it in this position. Lube the bore as well.
    Then wiggle it in and check from time to time if it's still compressed after a few tries or you might score the bore or the ring.
  2. 70-camaro
    70-camaro Veteran Member
    1,238
    162
    Mar 25, 2010
    marietta ohio
    Ok, I will try this later today.
  3. 70-camaro
    1,238
    162
    Mar 25, 2010
    marietta ohio
    2FB5182C-2AD5-4B49-B3E0-E2EB4E9EFEE9.jpeg 8BF1EA15-63D1-4C5D-930F-2941EAF65A46.jpeg 02553D6E-6035-4B67-A9C2-148D34F43C06.jpeg Is this all the further this piston goes in?
  4. 70-camaro
    1,238
    162
    Mar 25, 2010
    marietta ohio
    Got it in!! Lubraplate engine assembly lube helped. Now I want a firmer shift and need a different spring than green. Can anyone advise me on this. Thanks to everyone.
  5. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,183
    130
    Dec 13, 2009
    Deltona, FL
    Throw the spring into your neighbor's yard. That's what I did! I race my car and it shifts RIGHT NOW. It will be very quick and firm on the 1-2.
  6. 70-camaro
    1,238
    162
    Mar 25, 2010
    marietta ohio
    So don’t run a spring at all? A man here in town said he used to drag race and he put a bolt in place of the spring but once it came thru the cover. I am just cruising my car no racing. What about a stiffer spring?
  7. Blown Camaro
    1,183
    130
    Dec 13, 2009
    Deltona, FL
    Should be flying through the air already! The first time I saw a transmission builder do this I freaked out. He threw mine across the parking lot. LOL. Been doing to ever since when I do a shiftkit install. I only use the full Transgo kit BTW.
  8. 70-camaro
    1,238
    162
    Mar 25, 2010
    marietta ohio
    On the fence about no spring but it can’t hurt to try it I guess. I won’t be driving it till spring though.
  9. 70-camaro
    1,238
    162
    Mar 25, 2010
    marietta ohio
    BDBC0E66-20AD-4BE5-AB27-5845ADB47E84.jpeg 1DF7BA29-5E2A-423D-81A1-7A3E47B62CA6.jpeg Thought I would post pics of the piston in correct position.
  10. phat80
    phat80 Veteran Member
    1,019
    9
    Jan 4, 2013
    Victoria BC
    Glad you got everything worked out. Success!.
