TH 350 Accumulator removal??
Discussion in 'Transmission & Driveline Topics' started by 70-camaro, Dec 4, 2017.
  1. 70-camaro
    70-camaro Veteran Member
    1,065
    108
    Mar 25, 2010
    marietta ohio
    I bevieve this is the cause of my trans leak. Can I remove the accumulator with trans in the car? Any tips would be appreciated? Thanks in advance.
  2. phat80
    phat80 Veteran Member
    999
    Jan 4, 2013
    Victoria BC
    If it is the accumulator under the VB or separator plate you should be able to, but I'm sure there are others with far more experience than myself. Look at YouTube 350 tear downs and see where in the sequence they get to the accumulator.
    What are the symptoms...other than a visible leak?
  3. phat80
    999
    Jan 4, 2013
    Victoria BC
    DOH! I get it now you're talking about the accumulator on the side of the trans near the dipstick tube! That can be removed insitu although it is kinda cramped! There is a bolt hole above the accum "cap", to get the accum to compress put a thread in a bolt and use it as a pivot anchor for a bar and compress the accum. There should be a snap ring and/or a wick seal.
    Obviously the tricky part is getting the new seals well lubed and installed without nicking anything. Watch several vids on the method,and don't don't use grease to lube the seals.
  4. 70-camaro
    1,065
    108
    Mar 25, 2010
    marietta ohio
    3B1507BF-E606-4FF7-8FD0-3A603F67EC85.jpeg F3409DEC-9E63-44B2-A1F3-D30647B24060.jpeg 160E6981-3368-4AFF-8E85-799979373F18.jpeg 16AA644F-B173-48B6-8A34-181D2E03A128.jpeg I found these pics as to how to remove it but didn’t know if there was enough room to get it out because it is so close to the trans tunnel. It’s going to be hard working around the hedder and exhaust too. Haven’t watched any utube yet.
  5. camaro71/holland
    904
    24
    Aug 27, 2003
    The Netherlands
    It helps to push the cover in. To avoid damage, best way is to use a (large) glue clamp.
    Put some ATF on both the seals and the bore in the case.
    BPT catch more ATF than you would expect.
  6. camaro71/holland
    904
    24
    Aug 27, 2003
    The Netherlands
  7. 70-camaro
    1,065
    108
    Mar 25, 2010
    marietta ohio
    Good idea about the clamp. I may have to buy a bigger one because I don’t think mine is big enough. I definitely plan on having a drain pan ready even though I took the plug out of my pan this past weekend. It is still dripping by the way.
  8. camaro71/holland
    904
    24
    Aug 27, 2003
    The Netherlands
    Just check the 'depth' it needs to fit over the pan. Most won't clear the pan/VB.
  9. 70-camaro
    1,065
    108
    Mar 25, 2010
    marietta ohio
    856587C4-9A2C-42F4-A668-86BA658CB3B4.jpeg 153B2200-E96A-47E0-BCCE-00D5FAB6E934.jpeg AC6DEEC6-8F36-4A14-B599-B75BBE803833.jpeg Not much room to work. Probably won’t get to it until this weekend. Painting the bathroom this week in the evenings.
  10. Blown Camaro
    Blown Camaro Veteran Member
    1,024
    51
    Dec 13, 2009
    Deltona, FL
    We rolled the oring on mine and on the initial test drive it left an ATF stripe a foot wide all the way to the stop sign! Never leaked a drop until the car was moving. Paint in the butt to remove in the car but I got it done and sure enough, found a nick in the o-ring!
