Temp Sending Unit
Discussion in 'Troubleshooting & Diagnosis' started by Bob R, Apr 20, 2002.
  1. Bob R
    Bob R R.I.P 11/20/16 Staff Member
    4,219
    Jan 6, 2000
    Flower Mound, Texas
    Okay I am getting to the bottom of this. Looks like it is my Temp Gauge in the car that is screwy after all. Was working fine when I took it all apart. I got a couple of Temp Sending Units. One from Year One which is a GM Sending Unit and another from NAPA. I have yet to get the one from Ground Up Restorations out of NYC yet. I will test it when I get it. Here are the readings from a test of 4 Sending Units. These are all in OHM's.
    ORIG OLD GM NEW GM NAPA
    Cold 0 70 64 67
    Hot 0 16 15.5 17.5
    Cold being Room Temp (about 74 F) and Hot being 220 F. So other than the original that came on the car they all look fairly consitent. Now I guess I have to take the Cluster out to get to that Temp Gauge. If anyone wants the part numbers here they are.
    GM 478262
    NAPA TS6469
    Note the GM and NAPA look identical. They probably come from the same vendor. I will post the results of the Gauge when I get it repaired (in about 2 years).
    Thanks for everybody's help.
    Bob R
    1973 Z28 Original Owner 6 Year Frame Off Restoration
    1971 RS Z28 Frame Off Restoration in Progress
    http://www.geocities.com/bobr73z28
  2. Bob R
    4,219
    Jan 6, 2000
    Flower Mound, Texas
    The lastest news on this crisis, well not a crisis but things like this drive me nuts. Since the previous post (April) I have done absolutely nothing to the Temp Sending unit problem. I put a new one in (I think it was the GM one) and had the same problem.
    Now get this, yesterday I load the Z28 to go have my hood aligned (different story) and guess what is working now? The temp gauge works fine now. Geeez these things drive me nuts. Now if the !@#$ Tach would start working live would be good again.
    Bob R
  3. rscamaro73
    rscamaro73 Administrator Staff Member
    I was like 'WTF is this one doing back up top?' ...lol....
    Well, guess it might have needed a few heat cycles to drop into place ? Ehh...well, I wish that was all the 'worries' I had on MY car..... [​IMG]
    " ALL Camaros are equal, but some Camaros are more equal than others "
    73 LT 454
    mailto:rscamaro73@cox.netrscamaro73@cox.net</A>
  4. FSEVENTY
    FSEVENTY Veteran Member
    1,071
    Jan 31, 2001
    Mesa, AZ USA
    Maybe if you get your trunk realigned the tach might start working again!
    I know what you mean about the tach's as well. My origional tach would start bouncing around above 2,500 RPM and it was intermittent. Some days it worked and some not. I pulled it and TEMPORARALLY replaced it with one from late 70's Camaro. Someday after all of the other little problemn areas are taken care of I will drop the $$ to get it fixed or buy one of the $250 reconditioned ones from Year One or something.
    1970 RS
    350, 700R4, 3.73 posi
    I ride with &lt;&gt;&lt;
    Drive it till it wears out, rebuild it, then drive it some more!
    Pic of "Dada Racecar"
    [This message has been edited by FSEVENTY (edited September 15, 2002).]
  5. jakeshoe
    8,857
    Dec 8, 2000
    Republic of Texas
    FSeventy,
    Mine bounces at 25,000 rpm too, I think its SEVERE valve float...
    J/K. I know that was a typo. Wonder what a SBC would sound like at 25,000 rpm?
  6. FSEVENTY
    1,071
    Jan 31, 2001
    Mesa, AZ USA
    Wonderful and scary at the same time!
    1970 RS
  7. philly70ss
    philly70ss Veteran Member
    430
    Jun 9, 2000
    Lynn MA 01904
    "Wonder what a SBC would sound like at 25,000 rpms?"
    Probably like : KABOOOMM!!!
    1979 Z28 Black w/383 and too much to list
    1971 Olds Cutlass
    "the Thing"
    "IT'S CLOBBERIN'TIME"
  8. Bob R
    4,219
    Jan 6, 2000
    Flower Mound, Texas
    That is a good one FSEVENTY, I will threaten to do that to it this evening and let you know how it comes out! Bad Trunk Lid, Bad, Bad, Bad...
    Bob R
  9. GREGS396
    GREGS396 Veteran Member
    2,340
    Oct 16, 1999
    allentown pa
    Now I found the correct post for my sending unit info...on another note I had my 8k tach repaired by a guy near Pittsburgh for $125 and I works great. Mine used to stick at 3500, and at 2000 on the way down. I have his info if anyone needs it. Greg
  10. hogg
    hogg Veteran Member
    3,143
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    if tack and temp was not working ,sujest that you lost grd.of cluster,they use the same grd. in cluster,as does full gauge. i thank.
