Tanks EFI - Installation complete
Discussion in 'High Tech Retrofits' started by ULTM8Z, Jan 23, 2015.
  1. ULTM8Z
    ULTM8Z Veteran Member
    8,521
    127
    May 19, 2000
    Los Angeles
    Very nice quality piece, I must say.
    My comment in the other Tanks thread about the vent valve was incorrect. It's actually a check valve that only lets air in as the liquid volume decreases and wants to pull in air. It won't let fuel vapors out.
    Any rate, overall very happy with this set up.
  2. Joekool
    Joekool Veteran Member
    5,887
    25
    Feb 4, 2002
    Hollister CA USA
    How much did the total cost end up being and did they charge any shipping?
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,052
    46
    Feb 2, 2008
    SF
    Alright! Alright! Good job now post some pics!
  4. ULTM8Z
    8,521
    127
    May 19, 2000
    Los Angeles
    I bought a blem for about 40 bucks off and reused my existing pump. So all told it was about 400 with shipping.
  5. ULTM8Z
    8,521
    127
    May 19, 2000
    Los Angeles
    I'll take some shots of the car with it installed, but the pics of the tank itself is on their website.
  6. Fbird
    2,629
    178
    Feb 12, 2011
    atlanta, ga
    no pics????
    DIDN'T HAPPEN ;)
  7. sbca96
    sbca96 Veteran Member
    2,887
    Oct 25, 2004
    Santa Barbara, Ca
    I used the stock 4th Gen one with my EVAP 1973 tank into 1978 swap. The valve
    taps into the EVAP canister plumbing....
    For reference :
    http://www.nastyz28.com/forum/showthread.php?t=221572&page=3
    Tom
  8. ULTM8Z
    8,521
    127
    May 19, 2000
    Los Angeles
    Yeah, I ended up going back to my old third gen EVAP set up today. Required me to drill and tap a 1/8 NPT into the fuel level sender to put another EVAP port on the tank. Also, the third gen sender had a little check valve on the vacuum port to prevetn fuel from being sucked out... I had to remove that and use it to build a separate little external module to go in line on the purge line from the cannister.
    I have that same EVAP valve you're showing from a 3rd gen Camaro that I had been running with a '91 cannister and purge solenoid.
    The Tanks check valve wasn't enough to keep fuel vapors from escaping while the car is off, sitting in the garage. Garage smelled like raw fuel the next day.
  9. badazz81z28
    14,554
    149
    Las Vegas, NV
    Have any of you heard of Finch or II much fabrication? They have excellent vents I would suggest you look into them to attack the vapors. Simple install and an hoses
  10. ULTM8Z
    8,521
    127
    May 19, 2000
    Los Angeles
    Actually my set up works well for my application since the ECM, using the factory CCP settings, is already calibrated to work with the equipment I have.
