Tail pipes
Discussion in 'Engine Topic' started by johnnycamaroz, Dec 19, 2017.
  1. 80sz
    80sz Veteran Member
    2,240
    175
    Feb 2, 2014
    Buffalo,n.y.
    ^yup. Those are ones I bought from jegs. They fit good. I see you have center out on mufflers. That might be a little tight. I had offset/offset on mine. Still with a tweeking they prolly fit.
  2. jbloake
    jbloake Veteran Member
    247
    26
    May 1, 2002
    Were you able to use the factory hanger at rear frame rail , any pictures ?
  3. 80sz
    80sz Veteran Member
    2,240
    175
    Feb 2, 2014
    Buffalo,n.y.
    Yes. The rear hanger can be used. You will have to make the tab and weld it to pipe. No pics to share.
  4. Skip Fix
    Skip Fix Veteran Member
    2,008
    Mar 21, 2007
    Katy,Texas
    Look at the two piece Walker 2.5" mandrel bents. They do exit under the rear bumper. Two piece makes it easier to install and adapt to output on muffler.
  5. phat80
    phat80 Veteran Member
    992
    Jan 4, 2013
    Victoria BC
    Man we get our sphincter ripped livin up here in Canada. There ain't no 90$ pipes happenin here I'll tell ya. Also those 588101's will not fit 1980, they travel on each side of the fuel tank. tried 'em already.
