Tail Lights: One brighter than the others
Discussion in 'Troubleshooting & Diagnosis' started by Jerry Faltinek, Feb 4, 2018.
  1. Jerry Faltinek
    Jerry Faltinek New Member
    Feb 4, 2018
    I have one tail light that is much brighter than the others. I noticed both filaments are lighting up rather than just one. Just for fun, I put a 1156 with one filament in and that bulb still lights up brighter than the others
  2. Gary S
    21,637
    491
    If both filaments are lighting, you have a problem either with the way the socket is wired, or the socket itself is defective.
  3. Cardinal
    8,249
    16
    Jun 22, 2003
    Endicott, NY
    Are you sure you have the correct bulb for the correct socket? 1156 bulb goes in a single element single contact point socket. ll57 is a dual element bulb that goes in a duel contact socket.
  4. bourbon_scotch
    2,153
    79
    Jan 10, 2003
    USA
    does it look like this... lmao
  5. bourbon_scotch
    2,153
    79
    Jan 10, 2003
    USA
    so does this guy in the video have his brakes on then or what?
  6. Zspoiler
    Zspoiler Veteran Member
    2,894
    186
    May 6, 2012
    Federal Way, Washington
    Check your grounds ,socket snd then your bulbs.
  7. bourbon_scotch
    2,153
    79
    Jan 10, 2003
    USA
    check the bulb on the other side maybe they're both suppose to be on bright hahahaha
  8. Joekool
    Joekool Veteran Member
    5,915
    34
    Feb 4, 2002
    Hollister CA USA
    Probably a bad ground causing a back feed through the brake side of the filament.
