Tach Accuracy
Discussion in 'Troubleshooting & Diagnosis' started by MP81, Aug 22, 2017.
  1. MP81
    MP81 Member
    67
    Oct 10, 2016
    Washington Township, MI
    I finally got my car to stop eating speedometer cables (and reconnected it to the back of the gauge after it promptly fell off there the last time, because of course it did), and while driving it around on the freeway (driving to/from Woodward this past weekend), at around 75 mph it said it was turning close to 4,000 RPM.
    Based on my calculation sheet, 75 mph and 4k RPM do not correlate. While I'm not sure the speedo is accurate yet (I believe it was, based on my brother driving behind me on surface streets), I can certainly say the car was not at 4,000 RPM - because that would mean I was doing about 95 mph (and I definitely was not).
    Is this a pretty common thing? I figure the speedo should be pretty accurate given it's an entirely mechanical setup (with new upper and lower cables, and a new, correct, conversion box, along with new correctly-sized tires), so it can't really be wrong. The tach, however, is electrical, so it's entirely possible.
    Thoughts?
  2. CorkyE
    8,965
    159
    Those old tachometers are notorious for reading high, some not so much as others. What's the transmission/converter combo, rear end ratio, and rear tire size?
  3. MP81
    MP81 Member
    67
    Oct 10, 2016
    4-speed ST-10, 3:42 rear end and 225/70R15 tires (27.4" - should be the stock size).
    And that would make sense, given how quickly it gets to "5k" when I drive it. Would make a lot more sense if its reading of 5k was something lower.
  4. PalmbchZ28
    PalmbchZ28 Veteran Member Gold Member
    577
    184
    Jan 29, 2017
    West Palm Beach Fl
  5. CorkyE
    8,965
    159
    Yea, don't have to calculate that to tell the tach is off. If you're good with electrical, there's a thread on here about calibrating a tach, I would have to go search for it. I sent mine to Daniel at Guagemark, he's a site sponsor here.
    Treed on the link, here's Daniel's website; gaugemarks.com
  6. MP81
    MP81 Member
    67
    Oct 10, 2016
    Yeah, I'll need to go out and make sure that's what I was seeing, but I'm pretty sure it was 4k, because I was pretty surprised when it was that high (it's not like I'm running 3.73s or 4.11s or something).
    So you just sent the whole gauge (not the cluster/circuit behind it)? I've done small electronic stuff before (replaced many a capacitor on one of my computer monitors, multiple times, and in my mom's TV as well) - not a huge fan, but I can deal with it if it's not too bad.
  7. Dave Nelson
    3,201
    430
    Dec 19, 2003
    Vineland N.J USA
    At 75 mph with a 4 spd you should be around 3150 rpm's.
  8. MP81
    MP81 Member
    67
    Oct 10, 2016
    That jives with my calculations - and my fuel consumption. 4k on the freeway would've sucked fuel down like no tomorrow.
  9. CorkyE
    8,965
    159
    Yes it will, try TH350 with a 4K stall converter and 3.73 gears. :whine: That's why I went with a 700-R4.
  10. Twisted_Metal
    25,374
    325
    Does it possibly have a 6 cylinder tach?
