T56 reverse lockout wiring
Discussion in 'Transmission & Driveline Topics' started by 973800CamaroRs, Sep 15, 2013.
  1. Todd80Z28
    11,168
    97
    Jun 11, 2002
    Northern VA
    I didn't have mine hooked up for a few years. No harm done so far as I can tell. I've had my trans since '95.
    I just wired mine to a rocker switch right next to the stick. I would have preferred a momentary pushbutton right on the shift knob, but my Hurst knob doesn't lend itself to that.
  2. black_aerocoupe
    No. You're just compressing a spring.
    A momentary switch that stays "pressed" for several seconds would be best.
  3. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,981
    May 22, 2001
    Carmel, NY
  4. 973800CamaroRs
    973800CamaroRs Veteran Member
    703
    Nov 27, 2011
    Frederick Maryland
    Sweet guys ! I think I might see what it's like with our any switches then I may switch to a momentary button.
    Hopefully I get to test the car out tomorrow !!
  5. 79supergasdriver
    79supergasdriver A Scholar and a Gentleman
    768
    Jun 22, 2005
    Wichita, KS, USA
    Resurrecting a long-dead thread, but gotta ask the obvious question: the solenoid is inactive (not powered) when reverse is locked out and only active (powered) to retract and allow the shifter to move into reverse position? The momentary contact button makes a lot of sense in that case; simply tap button and move shifter. Kinda wish I could mount the button on the backside of the steering wheel but will likely put it on the center console.
  6. CAMeeks
    CAMeeks Veteran Member
    660
    29
    Jan 5, 2014
    Deer Park, TX
  7. badazz81z28
    15,273
    216
    Las Vegas, NV
    In the past I bought a shifter ball with a small button on the side. I think originally designed for nitrous, just wire it so when you push the button the solenoid is activated
