T56 reverse lockout wiring
Discussion in 'Transmission & Driveline Topics' started by 973800CamaroRs, Sep 15, 2013.
  1. 973800CamaroRs
    973800CamaroRs Veteran Member
    703
    Nov 27, 2011
    Frederick Maryland
    I see a lot of people who are wiring the reverse lockout to the brake light switch. I have the two wire connector in the trans now but how do i wire it to the brake switch ?
    Does anyone have a diagram even if it is crude ?
    Any other options ?
  2. black_aerocoupe
    + and -
    either polarity, 5 or 12v will work
    switched on below 5mph like the OEM tune is ideal.
    On a switch works too.
  3. 973800CamaroRs
    703
    Nov 27, 2011
    Frederick Maryland
    So do i run the power wire from the brake light switch bridge it to the lockout then just ground both of them ? Does it mater which wire i connect to ?
  4. BonzoHansen
    i originally used b/l circuit. I have since added a momentary switch under the dash.
  5. 973800CamaroRs
    703
    Nov 27, 2011
    Frederick Maryland
    I think I would rather hook it to the brake light, How did you have it wired Bonzo ?
  6. dale68z
    dale68z Veteran Member
    1,310
    May 14, 2009
    Glendale Arizona
    Ground 1 wire from the lock out solenoid.
    The other wire will be connected to the wire that is switched at the brake light switch. This wire will have power when the brake lights are on, no power when the lights are off.
  7. BonzoHansen
    i have a tendency to downshift from 6 to 5 approaching exits, so the BLS wasn't the best option. plus the RLO solenoid is kind of expensive to replace so i decided it was being over worked on the brake pedal.
    i just used relay.
  8. 973800CamaroRs
    703
    Nov 27, 2011
    Frederick Maryland
    Is it bad to just force it in ? can it hurt the lockout ?
  9. John Wright
    14,471
    148
    Aug 9, 2002
    Rustburg, Va
    How about using a N2O switch on the shifter? Press the momentary switch to activate, otherwise it would have the tension on it to help prevent accidental mis-shifting into reverse.
  10. BonzoHansen
    i don't think it is bad as much as it is annoying. it's easy to wire with a momentary button.
    I got a black momentary/normally open button at radio shack. You could just make it the ground side of the relay trigger circuit
    you can't see it.
