T5 or Super T10 or Muncie or Saginaw 4-speed?
Discussion in 'Transmission & Driveline Topics' started by 79supergasdriver, Apr 21, 2017.
  1. 79supergasdriver
    79supergasdriver A Scholar and a Gentleman
    768
    Jun 22, 2005
    Wichita, KS, USA
    Hello everyone!
    I recently acquired a '79 Z28 rolling chassis from a guy who was building a turbo LS/T56 setup for it. He abandoned the Z to put his big money power train into a '92 RS with sentimental value instead. So my Z already has the hydraulic clutch setup and modified trans tunnel to accommodate the large six-speed, but I simply do not have thousands laying around to drop on all that jazz. So what other options do I have that are compatible? The car has no cross member or driveshaft either.
    I found a T5 with early SBC bell housing for $300 but it sold within hours.
    Searching these forums lots of people seem to be looking for bits and pieces for Super T10.
    I learned to drive on a manual trans but have never had one in a Camaro. I have chewed up quite a few TH350's though. I'd realllllly like to have a fourth or fifth gear for comfortable cruising.
    I won't be racing this car in any professional or sanctioned capacity; my work schedule simply won't allow it. I'm being very optimistic for a ~400 WHP/6500 max rpm powerplant so don't necessarily need "bulletproof" stuff
  2. Zspoiler
    Zspoiler Veteran Member
    2,889
    184
    May 6, 2012
    Federal Way, Washington
    I would put in a Super T-10 in it .Since that what came in those cars. I have a 1979 Z-28 RS Pro-touring car. And I have done the Turbo 350 /Super T-10 swap..Because they have a couple of gear ratios available Stock) 2:64 and or Aftermarket )2:88 first gear. With a 3:42 gears .With a 500 HP plus Supercharged small block Chevy. And as long as I keep my foot out of it.(Of which be awfully hard at times)gets around 25 MPG at 2600 RPM with a 26 inch tall tire.Have fun. 130044932860518017_26257430996_o (1).jpg
  3. 79supergasdriver
    768
    Jun 22, 2005
    Wichita, KS, USA
    Is the Super T-10 compatible with a hydraulic clutch, or would I have to convert over to mechanical linkage? I have no idea if these cars came with hydraulic or mechanical clutch; again, I've only had TH350's in a different '79
  4. CasperCasper
    CasperCasper Veteran Member
    1,029
    122
    Aug 11, 2015
    You can easily run a hydo clutch using stock input bearing retainer too. I am using a ram on my ls/super t10 combo
  5. big gear head
    big gear head Veteran Member
    6,072
    42
    Jul 30, 2001
    Central City, Ky.
    A 3.42 first gear ST10 with a 3.08 rear end would keep your highway RPMs low. but this is the weakest of the ST10 transmission. Those cars came with mechanical clutch linkage, but you can convert it to hydraulic if you want.
  6. black_aerocoupe
    If the 92 RS was a V8 T5, grabbing that would be an option.
    No way would I put effort into not having OD.
    Save up for something you actually want, then save on gas.
    What rear gears are you starting with?
    2ndGen4Me likes this.
  7. Zspoiler
    2,889
    184
    May 6, 2012
    I have modified my mechanical linkage with Heim Joints it makes it real slick.
  8. 79supergasdriver
    768
    Jun 22, 2005
    Wichita, KS, USA
    The rear is 3.73 posi disc brake from a late 2nd gen firebird
    black_aerocoupe likes this.
  9. 79supergasdriver
    768
    Jun 22, 2005
    Wichita, KS, USA
    Previous owner already did. Still has master cylinder and line mounted
  10. F-Bodypilot
    F-Bodypilot Veteran Member
