T-56 Tremec rubber dust boot and leather shifter cover
Discussion in 'High Tech Retrofits' started by iraqivet, Jan 20, 2018.
  1. iraqivet
    iraqivet Veteran Member Lifetime Gold Member
    465
    23
    Nov 7, 2012
    Hobart, Indiana
    Putting in a T-56 Magnum transmission. What rubber boot did builders here use on their ride? Also what leather shifter cover is best? Also, do I just need the T-56 metal bracket sold out there or is a complete tunnel need to be raised? Using the 350 SBC. Thank you.
  2. Schubitzky
    Schubitzky Veteran Member
    319
    Mar 10, 2003
    Maryland
    I put a factory T-56 behind my SBC 350. I only had to cut the hole in my tunnel because the car was an automatic. Some people cut a larger hole or "raise" the tunnel to get the correct driveline angle. My driveline angle is about 3 degrees down so I didn't do that. I used the factory rubber boot from a 4th gen. You can get it from Hawk's Motorsports. For the boot I used a microsuede one from "sickspeed". If I recall correctly they had leather ones too.
    http://www.hawksmotorsports.com/shi...-6-speed-lower-shifter-boot-new-reproduction/
    https://www.sickspeed.com/product/black-suede-shift-boot-blk-boot-bundle
  3. iraqivet
    465
    23
    Nov 7, 2012
    Hobart, Indiana
