Swap TH350 for TH700R4
Discussion in 'Transmission & Driveline Topics' started by kphedges707, Jan 31, 2018.
Tags:
  1. kphedges707
    kphedges707 New Member
    Apr 14, 2012
    Clarksville
    This worked for me: 1981 Formula Firebird (Bandit Tribute)
    Purchased a constant pressure stage 2 TH700R4 rebuilt $1899
    Purchased aluminum drive shaft https://www.summitracing.com/parts/fms-m-4602-j
    Purchased 2 https://www.summitracing.com/parts/sdh-5-212x u-joints
    Reused yoke and crossmember
    Had to drill new holes in subframe for crossmember.
    Yes, that's a ford drive shaft. The length is perfect 45.5 inches. Weight 18lbs. The new u-joints fit the ends of the drive shaft, the other fit the yoke and rear end.
  2. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,282
    65
    Feb 2, 2008
    SF
    You can also have your old drive shaft shortened
  3. Revin
    Revin Veteran Member
    438
    54
    Aug 31, 2016
    Round Rock , TEXAS
    Nice!
    What kind of shifter?
    I guess the stock 350 shifter won't work with extra gear in the 700r4?
