Sunburnt dash pad fix?
Discussion in 'Interior Restoration' started by mason097, Oct 25, 2017.
  1. mason097
    mason097 New Member
    19
    Aug 2, 2017
    After having good success cleaning my stearing wheel, I pulled my dash pad off to clean it but the dash had a different problem. Instead of the black stuff being down in the low spots of the texture, the tops of the texture were blackened, and only on the top of the pad. I think it is sunburnt from sitting outside. Can I clean this out without having to sand on it? Would a scrotch brite work without damaging? Can I redye over the sunburnt portions?
    heres some pictures WP_20171022_18_21_14_Pro.jpg WP_20171022_18_21_20_Pro.jpg WP_20171022_22_30_27_Pro.jpg
  2. 70 Proof
    70 Proof Veteran Member
    400
    27
    Sep 28, 2014
    Southern Utah
    Assuming you don't want to replace the pad with a reproduction pad you can try spraying it with SEM brand Color Coat or something similar - after a good prep including a scratch pad. Go easy using the pad so as not to oliberate the grain. SEM has a tech line to give you advice on using their products.
    From the looks of your pad, IMO you would be better off replacing it or having it sprayed by a shop with the proper equipment and experience. You might consider a dash cap also @ about $100.
  3. brooksman9
    brooksman9 Veteran Member
    5,946
    107
    Jun 10, 2007
    Olive Branch, MS
    Clean it as best you can then SEM. Light coats. Unless you want to spend $400. The way I see it, it will get me by until I have the money for a new one.
  4. 70lt1z28
    2,246
    319
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Looks like there is some edge lift there too. You'll want to fix that before painting. It requires a hot air gun. You should be fine with the SEM products. Might also want to top with the matte clear for added protection. Use the adhesion promoter. You also may want to add the two more studs and clips on the underside to try and hold the edge down better.
  5. mason097
    mason097 New Member
    19
    Aug 2, 2017
    Thanks to all. 400$ is just too much I think. That much money will go a looong way on paint, my next step. Ill paint this pad a while before I install it on the car so I can see if it doesn't want to stick or the black shows through.
  6. hogg
    hogg Veteran Member
    3,150
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    that may be the true color ,black, be for it was brown
  7. mason097
    mason097 New Member
    19
    Aug 2, 2017
    ahhh. Thats a good thought. I'm interested to see if that's true. On the inside of the cap it says "1974-5," so it may have been taken off of a black interior 74 or 75.
  8. budro6968
    budro6968 Veteran Member
    2,483
    343
    Apr 2, 2016
    Jax Florida
    I used Sherwin Williams Ultra 7000, They had an additive for their paint line that turned any tint or color you wanted into interior paint or dye. I used denatured alcohol to wipe down. It evaporates nice and clean. Ask your local paint supply people what will work. The additive I used worked with just about every paint I tried. PPG, Dupont etc.. Some interior guys used latex based paint that will look great until you try to clean with ammonia based cleaners. That would cause it to lift.
  9. Bandit723
    Bandit723 Veteran Member
    2,663
    324
    Oct 1, 2016
    Waupaca WI
    I use the PPG SB series dye works really well. Your local PPG dealer should be able to match your color.
  10. Fbodywarehouse
    Fbodywarehouse Veteran Member NastyZ28 Sponsor Lifetime Gold Member
    2,421
    8
    Mar 7, 2006
    On the edge lift ya take some 1x1s and cut them down to fit between the studs heat the wrap with a heat gun and clamp them tight, re-staple and let cool, will straighten that edge right out, then redye using SEM and SEM low luster clear, Dont use Hi Gloss clear or you'll blind yourself with the sun reflection.
