subframe bushing replacement questions
Discussion in 'Troubleshooting & Diagnosis' started by slick78, Feb 15, 2008.
  1. slick78
    slick78 Member
    74
    Jan 28, 2008
    Centreville, VA
    I'm replacing the inner fender and battery tray on my 78, and the subframe bushing is in horrible shape so need to replace that too, (thanks Twisted_Metal for pointing it out in my "rusted battery platform" thread).
    Check it out...pretty nasty:
    I'm not sure exactly what I need for this...I've looked through some of the parts catalogs and I'm a bit confused on what I need in terms of bolt(s), washer(s), bushing(s) and biscuit(s)...
    Can you guys give me an idea of what parts I need, and also any suggestions on doing the job?
    Thanks!
  2. Marks71BB
    I would bet the rest of em look just like that one.
    There has been a lot of info posted on sub frme bushings here. It depends on what you will be doing with the car. There are basicaly three options. 1. factory rubber, 2. urethane, or 3. solid mounts.
  3. kik_start
    kik_start BANNED
    3,296
    Sep 3, 2006
    gone crazy
    You forgot the last option...leave it alone.
  4. Marks71BB
    he wont leave it like that.
  5. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    You should be able to buy a kit with everything you need. For example: http://store.summitracing.com/egnsearch.asp?N=700+4294881579+4294908216+4294908198+115+4294925060
    NPD, and I'm sure many other places, sell the rubber bushings. Poly will tighten up the body a little. If you ever plan on adding sub-frame connectors, install solid mounts now & be done with it. Protouring f-body (on this board) sells a nice kit with the solid bushings & all the hardware you need.
    Here is a great how to: http://www.nastyz28.com/forum/showthread.php?t=17406&highlight=subframe+bushing
    Edit: PS, good luck getting that bolt out. It looks a little rough. +1 on just doing them all...
  6. frozenbowtie
    frozenbowtie Veteran Member
    119
    Jan 21, 2008
    Fairbanks Alaska
  7. pete0331
    pete0331 Veteran Member
    656
    Mar 26, 2006
    Kitsap, WA
    I installed the PTFB ones a few months ago, and I am happy with the results.
    Replace them all at the same time, and from the looks of things you have quite a job ahead of you.
    Start soaking all of them with PB Blaster now, so by the time the bushing get there you will be ready to throw them on.
  8. Toomanyhobbys
    Toomanyhobbys Veteran Member Lifetime Gold Member
    2,807
    Apr 12, 2005
    Mesa, AZ
    Use the OEM's for street. Do a search, 67Lemanster and others did a super write up on replacing them
  9. slick78
    slick78 Member
    74
    Jan 28, 2008
    Centreville, VA
    That's awesome, thanks for all the info!!
    Gonna order the kit and start soaking the bolts today. I'm thinking I'll go with the poly.
    Great write-up in the other post on how to do it, (tip on jack placement is priceless). Looks like the hardest part of the job will be getting the old bolts out...
  10. Marks71BB
    Good luck slick! Let us know how it turns out for ya.
