Struggling With Understanding Engine Timing Concepts
Discussion in 'Engine Topic' started by Bandit723, Jul 24, 2017.
  1. Bandit723
    Bandit723 Veteran Member
    2,754
    330
    Oct 1, 2016
    Waupaca WI
    Have read thru numerous posts on this topic. I get the vacuum advance theory but what is out on the internet seems to be a bit vague when it comes to to figuring out the mechanical advance settings or what total timing really is.
    So example my mechanical all in dist set and locked at 28 degrees advanced all in but am idling at 16 degrees advanced what is my total advance when running all in?
    So no matter how i set the idle advance i end up with 28 degrees so 10 advanced at all in still times out to 28 and 20 advanced still times out to 28.
    Have seen a number of calculations that spell this out so just looking so is is my total timing 28 degrees with a mechanical advance of 8 degrees 28-20 = 8 or is it 28 total? or is it 28 + 20 for a total of 48 degrees.
    Not the best question but just looking to understand this.
  2. biker
    biker Veteran Member
    Your vacuum advance must be disconnected in order to know what your actual initial timing is. Sounds like you are getting some advance from vacuum if you can change total and not get much diff on initial reading.
    Your distributor has a certain amount of mechanical timing bult into the mechanism. As revs go up, this advances until it hits its limit. Whatever you add to that by setting initial timing at idle is the total timing. When driving, any vacuum advance you have will disappear whennthe engine is loaded at full or mostly full throttle.
  3. biker
    How are you setting your total timing? Using a dial back light or totally marked harmonic balancer?
  4. wiseryder
    2,051
    39
    Sep 11, 2004
    belding,mi USA
    But if his Dist.Is locked,
    Vacuum wont work correct?
    Ive nvr ran a locked out Dist.
  5. Bandit723
    2,754
    330
    Oct 1, 2016
    Waupaca WI
    Should have clarified i am not using any vacuum advance so still unclear what the total advance is.
  6. Bandit723
    2,754
    330
    Oct 1, 2016
    Waupaca WI
    Correct
  7. wiseryder
    2,051
    39
    Sep 11, 2004
    belding,mi USA
    Seems to me his total would be 28 then
  8. Bandit723
    2,754
    330
    Oct 1, 2016
    Waupaca WI
    I do have a dial back light and good marks on the on the balancer. so 16 on the light = 0 on the timing marks 28 on the light = 0 on the timing marks.
  9. Bandit723
    2,754
    330
    Oct 1, 2016
    Waupaca WI
    I would think so but just not sure.
  10. 80sz
    80sz Veteran Member
    2,885
    317
    Feb 2, 2014
    Buffalo,n.y.
    Timing total is what you have on crank + mechanical built into distributer + what the vac advance pulls. Using a dial back timing light see what crank reads then rev up till advance stops. hold that rpm,starting at zero turn dial up on light till it reads what you had on crank at idle. The mark will move backwards . What it says on light will tell you how much mechanical is built into the distributer. Then at part throttle the vac canister will pull a additional 10-15 degrees. At wot there is little vac so the canister wont add anything. If you got 15 on crank + 21 mechanical you got 36. Then the canister will add 15 to that giving a total of 51. The vac advance is only for part throttle conditions. A typical distributer has 21 degrees built in.
