Stick adhesive tape!!!!
Discussion in 'Detailing Topic' started by ziggy, Jan 10, 2015.
  1. ziggy
    ziggy Veteran Member
    199
    Aug 17, 2014
    Ghent, WV
    How can I remove 3m tape from fender that a jack ---- stuck a Z28 emblem on 76 camaro!!! Any remedies to remove the adhesive tape????
  2. 8pack
    2,459
    90
    Aug 29, 2007
    Pittsburgh, PA
    Goof off, mineral spirits.....just get it good and wet, let is soak and be patient rubbing it off....
  3. 76_TypeLT
    6,411
    144
    Jul 26, 2008
    Houston, TX
    I'd first take a hair dryer and slowly heat the adhesive and attempt to CAREFULLY remove the tape. Just take your time.
  4. ziggy
    199
    Aug 17, 2014
    Ghent, WV
    Will try both, is it called goof off? This is stuck on hot rod black paint will the mineral spirits hurt paint?
  5. Twisted_Metal
    26,358
    638
    I use Goo Gone.
    Just removing some double-sided tape residue from the inside of my fender with it today.
    (Remounted my headlight relays.)
  6. la-rue
    la-rue Veteran Member
    437
    Sep 30, 2013
    SF Bay Area, Ca
    close to the above, but a heat gun gets the job done faster than blow dryer. The higher heat helps. Heat up for a second and then go in with your thumb to try and slowly roll it away.
    Depending on your paints type/condition, some of the chemicals can hurt the finish, though I did not have that issue when I used it. I used goo gone and good off the first time I had to remove adhesive tape, and while it did eventually get the job done, the heat worked much better. (Goof off is stronger than goo gone)
    Also, depending on how think the left over stuff is you may be able to shave some off with some fishing line. Grab a length of line and wrap it around your hands and just saw off as much as you can.
  7. ziggy
    199
    Aug 17, 2014
    Ghent, WV
    Will the goo gone hurt the hot Rod Black paint finish?
  8. hogg
    hogg Veteran Member
    3,163
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    I just use more newer tap ,put it over the old stickie and let it set for a while then jurk it off
  9. la-rue
    437
    Sep 30, 2013
    SF Bay Area, Ca
    ^iikebthwt idea. Worth giving a shot first.
    Test it in an area that you can't see. I wouldn't be surprised if it did leave a mark
  10. daddio4048
    daddio4048 Veteran Member
    818
    Jan 21, 2013
    Valdosta,Ga.
    WD-40 works good on loosing adhesive & it wont hurt the paint.
