Starter motor wiring support
Discussion in '1970 - 1973 Specific' started by Gmenadue, Sep 11, 2017.
  1. Gmenadue
    Gmenadue New Member
    18
    Apr 25, 2014
    South Australia
    I'm trying to find out about the nylon bushes that are on two of the starter motor leads.
    Are they used with the wiring retainer that clips to the starter motor?
    If so, is there just one retainer, supporting all of the leads or one lead per retainer clip?
    Photos are always a bonus.
    Cheers
  2. Twisted_Metal
    26,051
    529
    Those nylon "barrels" are the connections for the fusible links.
    (From the barrel to the terminal it's a smaller gauge fusible link designed to act like a slow-blow fuse to protect the rest of your wiring harness.)
    The wires normally route through a steel tube to keep them away from the exhaust system.
  3. Twisted_Metal
    26,051
    529
  4. 74BIBELOT
    74BIBELOT Veteran Member
    IMG_5056.jpg Not a good pic, but you can see the fuse links( barrels) coming out from conduit tube:
  5. bodymanbill
    bodymanbill Veteran Member
    923
    196
    Feb 1, 2007
    South Park Pa
    image.jpg Here's a pic of mine on my 73 when i was putting it together. It's a little dark but u can see it alittle bit
  6. Gmenadue
    Gmenadue New Member
    18
    Apr 25, 2014
    South Australia
    Thanks for all of the responses. A great help again
