spindle - upper ball joint fit
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, Sep 11, 2017.
  1. Chuck71RS
    1,011
    24
    Nov 24, 2012
    Houston, Texas
    One spring installed with the bottom end about half way between the two holes in the lower control arm.
    Is the upper joint stud fitted correctly in the spindle? The nut is torqued to 50 ft lbs. I thought the dust boot would be parallel with the spindle
  2. CorkyE
    9,035
    170
    It will be more squared when you put the wheels on and set it on the ground. Remember to leave the a-arm bolts a bit loose, tighten them loaded.
  3. BonzoHansen
    its at full droop in your pic
  4. Chuck71RS
    1,011
    24
    Nov 24, 2012
    Houston, Texas
    Thanks gents. Slowly but surely I am getting there with it being done correctly this time. Now to install the other spring.
