Speedometer cable length
Discussion in '1970 - 1973 Specific' started by steins70z28, Apr 9, 2017.
  1. steins70z28
    steins70z28 Veteran Member
    199
    22
    Apr 14, 2012
    Tulsa, OK
    I have a 70 with a turbo 400 with short tail shaft. Trying to figure out the correct speedometer cable length. To many to choice from! Any help would be appreciated.
  2. 71 cam
    71 cam New Member
    11
    Dec 16, 2013
    australia
    Hi Stiens ive got a 71 with a 400, the cable i just changed out was 58 inches.
  3. steins70z28
    199
    22
    Apr 14, 2012
    Tulsa, OK
  4. steins70z28
    199
    22
    Apr 14, 2012
    Tulsa, OK
    Was that the length of an original cable or a replacement that you installed. Eckler's has a 62 inch cable with firewall grommet installed. Was trying to figure out if it would work? Any thoughts would be appreciated.
  5. 71 cam
    71 cam New Member
    11
    Dec 16, 2013
    australia
    58 inches looked like an original
  6. steins70z28
    199
    22
    Apr 14, 2012
    Tulsa, OK
    Thanks so much for the info.
  7. Jon's72
    Jon's72 New Member
    12
    Aug 31, 2010
    Los Angeles, CA
    I have a 72 Camaro that is an original 350 4 speed car with a Saginaw. I getting ready to install a TKO-600 kit from American Powertrain this week. Same problem as above I need a speedometer cable but my car doesn't have one either. The kit comes with an adapter/extender to make the stock cable work. What is the correct length I need? I've seen upper cables referenced in catalogs was it a 2 piece cable? Has anyone else done the same swap (Saginaw to TKO-600) what cable length worked? Any help would be appreciated!
    Thank
    Jon
