Speedometer cable leak
Discussion in 'Transmission & Driveline Topics' started by 7.62fmj, Oct 21, 2017.
  1. 7.62fmj
    7.62fmj Member
    82
    May 16, 2017
    Jacksonville, Fl
    What is this thing between my speedo cable and transmission and how do I get it to stop dripping?
  2. Green hornet
    Green hornet Veteran Member
    1,074
    141
    Oct 11, 2015
    North Bay, CA
    I believe they call it a bulit (M/T) It has an O-ring on the outside. I had to replace mine because of leaks. The O-ring shrunk over the years and wouldn't seal. What a mess.
  3. tom3
    tom3 Veteran Member
    10,761
    77
    Aug 1, 1999
    ohio
    Have to sign in to see picture, but there is also a very small seal inside the bullet that runs on the speedo gear shank.
  4. Burd
    438
    71
    Oct 6, 2011
    Detroit Mi
    I recently bought the O ring and the seal at the Dealer, are you referring to the little gear box to correct the Spedo? Spec on here in Detroit may have those. They carry the diff color gears.
  5. Burd
    438
    71
    Oct 6, 2011
    Detroit Mi
    Here's the Numbers and both seals, the O rings come In a 5 pack. I have 2 extra. 3$ ea if anyone needs one. The black seal is sold separately
  6. 7.62fmj
    7.62fmj Member
    82
    May 16, 2017
    Jacksonville, Fl
    The piece that's leaking doesn't have the external o-ring. It's more of a bone shape, and it's a couple inches off the trans. The bullet is the conical piece that holds the gear in, right? Screwed right into the side of the trans? Is this some kind of adapter or something?
    I don't know much about transmissions, but I haven't been able to find a Speedo bullet that looks like in the pic.
  7. Lou6t4gto
    Lou6t4gto Veteran Member
    184
    Aug 18, 2010
    Ocala, Fla
    alot of these cars used a "Reduction box", a 90 degree looking thing that the cable attaches to and it screws onto the trans bullet that holds the speedometer gear. I HAD one on mine, it's in the garbage now. I put in the correct speedometer gears and a cable extension.
  8. 70lt1z28
    1,566
    171
    Oct 3, 1999
    Beavercreek, Ohio, USA
  9. 7.62fmj
    7.62fmj Member
    82
    May 16, 2017
    Jacksonville, Fl
    Yep, looks like a reduction box. The four corner screws are pretty tight, but it's seeping just a bit through the seam between the two halves.
    Also, how tight should it attach into the trans? I was told it can be somewhat loose, but that doesn't sound right to me.
