spare
Discussion in '1970 - 1973 Specific' started by usmlsmk, Dec 30, 2011.
  1. usmlsmk
    usmlsmk Member
    48
    Feb 24, 2010
    roscoe il
    This is the tire thats been in the trunk for the 20+ years ived owned the car. Is it the original spare if so how can I find orig jack set up. 1973 r/s350 stick.Thanks
    [​IMG][/IMG]
  2. usmlsmk
    usmlsmk Member
    48
    Feb 24, 2010
    roscoe il
  3. 80WA7113
    80WA7113 Veteran Member
    1,366
    May 22, 2002
    Indianapolis, IN
    Nice ride, and you ask a very good question---I thought the tires (including spare) installed on the '73 Camaros were all Goodyear, and yours is a Uniroyal...I'll say that it appears as if it could be original. This would be a good question for BobR to answer, as I'm not sure if the non-Z28's came equipped with Uniroyal tires or not.
    As for the jack, they are the same for all 1970-1973's, but if you're looking for an original "1973 date coded" jack, your only options at this point are ebay, swapmeets, or possibly here in the Swapmeet section. If "date coded" is not important, both the correct style jack and cover are available new aftermarket. Here are 2 examples I found on ebay:
    JACK
    JACK COVER
    Hope this helps!
  4. usmlsmk
    usmlsmk Member
    48
    Feb 24, 2010
    roscoe il
    Thanks. I have everything but intake carb(2bl) and trans 3speed to make original. Orig jack would be cool
