Something to make moving engines around easier
Discussion in 'Tips 'n' Tricks Topic' started by Mark Davis, Nov 17, 2001.
  1. Mark Davis
    Mark Davis Veteran Member
    I saw this one at a car show, and forgot about it.
    Take a couple of 6inch long bolts, the right size to go in two of the forward and rear facing bolt holes tapped into your block, wrap them with a 5inch length of the proper size fuel line for grip, and screw them in. Now you have some handles to use when you muscle that engine on a stand around the garage.
    '71 Camaro
    Black 402 BBC
    B&M TH400, 11" 3500 stall
    (no times yet, got to do the brakes before I go to the track.)
  2. C-Man
    C-Man Veteran Member
    2,544
    Oct 3, 2001
    Port Orchard WA.
    the first time I ever had to move an engine a long distance I used a skate board I've also used a creeper.
  3. Mountaineer
    Mountaineer Veteran Member
    I have an old supermarket shopping cart, cut off the top basket, the bottom shelf will hold and move a tranny no problem!
