?? solid headliner in a 71
Discussion in 'Interior Restoration' started by Chuck71RS, Feb 10, 2018.
  1. Chuck71RS
    1,134
    39
    Nov 24, 2012
    Houston, Texas
    In my 71, can a solid headliner be installed in place of the 6-panel bow type?
    I prefer the look of the solid style with the smoother contour.
    Also want to add a low profile twin light fixture at the front windshield between the sun visor. The headliner would provide a route for the wiring.
    Could also insulate the overhead
  2. 70pete
    70pete Member
    92
    10
    Aug 19, 2014
    martinsville, nj
    I just did it in my 70 and was able to use all my original trim pieces. I'll post pictures later. This is the headline i used, you need to email him a tell him you want it for a 70-73 and he will fill in the seat belt cutout. i had him add extra material on the ends and not glue the last 2" so i can adjust the board. i also insulated the roof with the Lowes stuff.
    https://www.ebay.com/itm/1974-1981-...ash=item5d798a2f12:g:U5YAAOSw241YVVN4&vxp=mtr
    Chuck71RS likes this.
  3. Chuck71RS
    1,134
    39
    Nov 24, 2012
    Houston, Texas
    Hello Pete and thanks. Excellent news all around. Just looked at the ebay link. No problem with the price. Look forward to seeing your photos
  4. 70pete
    70pete Member
    92
    10
    Aug 19, 2014
    martinsville, nj
    Here are some pictures. They came out pretty dark, i'll try to get better ones. Unfortunately the previous owner put in a sunroof and i don't fell like tackling that project yet to remove it. I do have an original 70 roof section for the future. Headliner comes with some insulation on it already. I did glue and staple wood stringers on both side to stiffen up, i think because of sunroof it was deforming it. You will have to trim and play with it to fit nice.
    headliner6.JPG headliner.JPG headliner1.JPG headliner2.JPG headliner3.JPG headliner4.JPG headliner5.JPG
    71RSLS likes this.
  5. BillyDean7173
    BillyDean7173 Veteran Member
    784
    104
    May 21, 2014
    Hutto, TX
    Previous owner of my 71 put an OEM board in the car, but no headliner. Fit well and had the seat belt cutouts. Took it out because the old foam deteriorated bad and would blow around the car and get in my eyes.
    Back in high school, my 77 Firebird had a board and no headliner. I used a big AC/DC tapestry for the headliner. Came out great.
  6. Chuck71RS
    1,134
    39
    Nov 24, 2012
    Houston, Texas
    Pete, in the 2nd photo, I see irregular lines in the liner material. Is this so or is the material smooth?
  7. 1971CamaroGuy
    3,530
    99
    Oct 31, 2004
    Arkansas
    Pete, what is that made out of?
  8. 70pete
    70pete Member
    92
    10
    Aug 19, 2014
    martinsville, nj
    Its pre contoured on the ends to make the curve down.
  9. 70pete
    70pete Member
    92
    10
    Aug 19, 2014
    martinsville, nj
    made of the same material used in 74 and up, he supplies extra to do sunvisors
  10. 1971CamaroGuy
    3,530
    99
    Oct 31, 2004
    Arkansas
    Is it press board? Plastic? Pics are hard to tell?
    The reason I ask is I have a solid headliner, but it's seen better days..if I knew what material was used on that I could try source some locally. Then trace my headliner onto the new material.
    Thanks
