Small parts needed
Discussion in 'Swap Meet Section' started by seventy7camaro, Jan 20, 2018.
  1. seventy7camaro
    seventy7camaro Veteran Member Lifetime Gold Member
    I'm looking for an electrical connector that plugs onto the engine temperature sensor. The same plug is used on the fast idle switch for air conditioned cars. My connector's plastic body has been glued repeatedly and is no longer usable. If possible, I'd like to have a couple of inches of wire to work with too or you can just remove the electrical part and let me have the plastic body. Then I can put my existing electrical piece inside. I'm also looking for a radiator support horn wire grommet. These are for my 79. Thanks in advance.
  2. dave@ztech
    1,796
    236
    Mar 27, 2016
    NY
    check Del city, they have the replacement I believe, and the new tangs if needed,
    www.delcity.net
  3. silver81
    silver81 Veteran Member
    146
    Mar 8, 2008
    Western Wyoming
    classic industries ca34620 kit lets you build the one you need. about 12 bucks.
  4. seventy7camaro
  5. seventy7camaro
  6. seventy7camaro
  7. CamarosRus
    CamarosRus Veteran Member
    After ALL that you cant confirm to other members where in fact you bought
    the CORRECT pieces !!!!!!!!!!!!!
  8. seventy7camaro
    Well, as for the grommet, I found it along with another in a box where I'd put them several years ago. The electrical connector was in a box of connectors that I toss my "good" wiring and connectors into. There's also a choke tube pipe that I'd been looking for...well, berg2695 had what I needed. The silver paint that I was looking for the code for my '79 YJ8 wheels... well the folks at Alloy Wheel Repair Specialists kept that paint code.... a business secret I guess. Thanks for any time any of you expended to look for these parts for me. I'm sure I'll be looking for other parts and will also look for any parts I may have that you all need.
