Slow left hand turn causing rattle/tick noise from BW 4 speed
Discussion in 'Troubleshooting & Diagnosis' started by SH74OUR, Aug 13, 2017.
  1. SH74OUR
    SH74OUR Veteran Member
    243
    May 27, 2013
    london ontario
    I'm really racking my brain as to what would cause a slight rattle or tick like noise to be emitted from a Borg Warner Super T-10 4 speed trans when your making a slow speed, sharp left had turn.
    The trans has to be in 1st gear, clutch engaged for this noise to happen. If anything changes, the noise goes away.
    I'm really hoping someone has experienced this type of noise.
    Thanks.
  2. Joekool
    Joekool Veteran Member
    5,863
    22
    Feb 4, 2002
    Hollister CA USA
    Check your engine mounts and subframe mounts, the z-bar is attached to the engine and subframe, any movement under load could be screwing with the clutch linkage/throwout bearing.
  3. SH74OUR
    243
    May 27, 2013
    london ontario
    I'm 99% sure this is not the issue. At first I thought I was something similar to this but everything is solid and new.
  4. harbone66
    3,443
    244
    Feb 15, 2011
    Central Illinois
    Sure its not coming from the rear axle?
  5. SH74OUR
    243
    May 27, 2013
    london ontario
