shorter transmission mounts?
Discussion in 'Transmission & Driveline Topics' started by Goat, Oct 27, 2017.
  1. badazz81z28
    14,270
    122
    Las Vegas, NV
    Driver side
  2. Goat
    1,710
    14
    Jun 7, 2001
    moncure, NC
    It looks like the centerline of the horizontal through bolt is centered between the upper and lower mount bolts. If so, the height should not change...I'll call DSE tomorrow and verify. Thanks for your help.
  3. badazz81z28
    14,270
    122
    Las Vegas, NV
    Heres Tim's Car.
  4. badazz81z28
    14,270
    122
    Las Vegas, NV
    a 3rd one for your comfort. DSE will tell you this is the right way. Not sure if it makes a difference.
  5. Goat
    1,710
    14
    Jun 7, 2001
    moncure, NC
    I'm not doubting your claim. I'm past that. Just now wondering if it matters...
  6. Goat
    1,710
    14
    Jun 7, 2001
    moncure, NC
    You said... " DSE will tell you this is the right way"
    I'm not disputing you!
    I said... "If so, the height should not change...I'll call DSE tomorrow and verify".
    I want to ask DSE if reversing the mounts makes any difference...
  7. badazz81z28
    14,270
    122
    Las Vegas, NV
    I'm anal, I would want it right regardless. Do you have time to swap them and just see what happens?
  8. 71RS/SS396
    71RS/SS396 Veteran Member
    2,587
    19
    Aug 26, 2008
    Wake Forest NC
    You definitely have the mounts on upside down and it does matter, it changes the height which might be why you had a hard time getting the engine in there.
  9. Goat
    1,710
    14
    Jun 7, 2001
    moncure, NC
    Ok, there many be other reasons for swapping the mount 180, but I don't see it changing the height significantly. Look at the picture. The centerline of the horizontal bolt is almost centered between the two mounting bolts. Swapping it 180 does not look like it will make much difference. I measured the distances and the black bolt is about 1/8" farther away from the centerline than the gold (upper in picture) bolt. In fact, it looks like to me rotating it 180 will actually raise the engine some fraction of an 1/8".
    At any rate, going to change it for peace of mind if nothing else...
  10. badazz81z28
    14,270
    122
    Las Vegas, NV
    Not sure, but something is telling me it's affecting the fore-aft placement of the engine. I believe the bottom bolt goes in a tapped hole and the top do not. I'm interested to see what changes getting them right does
