shifter change out
Discussion in 'Original Drivetrain Topic' started by arm2004, Feb 25, 2018.
  1. arm2004
    arm2004 Member
    32
    May 5, 2017
    S.E. Ohio
    I am going to start changing from a column shift to a floor shifter on a 1970. I have the a factory "U"shifter, cable and center console. What else do i need to hook this up to turbo 350. wanting to make sure i have all the parts before i start. Thanks
  2. 70-camaro
    70-camaro Veteran Member
    1,236
    161
    Mar 25, 2010
    marietta ohio
    You will need the bracket that bolts to the transmission pan bolts for the transmission end of the cable. If you want to hide evidence of the column shift you will need the sleeve for the column for floor shift car.
  3. arm2004
    arm2004 Member
    32
    May 5, 2017
    S.E. Ohio
    Thank you i have located the trans bracket. Will figure out what to do with the column. I see you not far from me i am in Vincent might run into you some time.
  4. arm2004
    arm2004 Member
    32
    May 5, 2017
    S.E. Ohio
  5. arm2004
    arm2004 Member
    32
    May 5, 2017
    S.E. Ohio
  6. 70-camaro
    1,236
    161
    Mar 25, 2010
    marietta ohio
    That cool. We will have to check out each other’s Camaros sometime.
  7. Gary S
    21,077
    305
    The floor shifter will require the backdrive linkage to make the steering lock work on the column. The Assembly Manual is a good source for pictures and part numbers.
  8. 70-camaro
    1,236
    161
    Mar 25, 2010
    marietta ohio
    I like cruising the Camaro out 550. Fun road to drive it on.
  9. 70lt1z28
    1,959
    249
    Oct 3, 1999
    Beavercreek, Ohio, USA
    This stuff:
  10. l16pilot
    1,585
    75
    Dec 13, 2004
    Hurlock, MD, USA
    Correct me if I am wrong, but since it is a column shift car, isn't the back drive already in place and connected? It would seem to me the only necessary items would be the components noted above to connect the floor shifter to the trans.
    Also...and this is just a thought. On column shift cars, doesn't the column shift lever need to be pulled toward the driver to disengage and allow movement out of park? if the column shift lever is removed, how would the disengagement take place when activated by the floor shifter?
