Sheetmetal Choices
Discussion in 'Body Restoration' started by jetech1, Oct 26, 2018.
  1. R.Jones
    R.Jones New Member
    21
    Feb 8, 2018
    What about dynacorn parts and golden star? To know which brands are the best is a very confusing issue. Our we sure their not all made in the same overseas factor and just labeled differently?! Lol.
  2. 75Maro
    75Maro Veteran Member
    319
    9
    Mar 31, 2008
    Dallas,Tx
    I agree with the above post. Most likely all built in the same plant with different labels.
    hubedobeedo and R.Jones like this.
  3. hubedobeedo
    hubedobeedo 3rd times a charm
    65
    11
    Jul 18, 2013
    Huntertown,IN
    i suspect they are i know years ago alot of auto manufacturers sold their old dies when they updated models which created fitment problems when aftermarket companies made parts with them.i remember using comealong to pull down fender on my brothers pickup but it only cost 60 bucks lol i also had fitment problems with some of the sheetmetal i bought got most from tamraz on ebay all asian the rear filler between decklid and rear window was from company that went out of business it fit nice if you can get used oem or nos you will have less fitment problems but spend time on fixing rust be aware just because parts are new or look rust free there are place on all parts that need attention to avoid future rust thru fender braces from factory and aftermarket are not fully coated i found out when i had issues with fitment and removed originals to use on aftermarket skin i imagine that is why all camaros have that rust thru issue on bottom of fenders relizing that i have spent alot of time on all other panels on my build boy that was long winded hope it helps
  4. lapedr
    lapedr Veteran Member Gold Member
    552
    12
    Jan 28, 2003
    Pembroke, GA
    I bought AMD quarters, outer wheelhouses, tail panel, crossrail, and RH fender and they are awesome. I hardly had to do any tweaking on the LH qtr.
    hubedobeedo, jbloake and bodymanbill like this.
  5. hubedobeedo
    65
    11
    Jul 18, 2013
    Huntertown,IN
    that does look good nice gaps are you using different tail panel? if so post pics
  6. smokeatr23
    smokeatr23 Veteran Member
    211
    Dec 24, 2014
    United States
    Wish mine looked that good. I got crap from Camaro central and the door vent was about 1/2" too low on one. The outer wheel wells didn't fit correctly either.
  7. lapedr
    552
    12
    Jan 28, 2003
    Pembroke, GA
    Yes I have a new amd tail panel supposedly new tooling, it seems pretty heavy
  8. 70ZED
    70ZED Veteran Member Gold Member
    323
    20
    Jun 21, 2010
    Calgary, Alberta Canada
    I see your bottom bodyline doesn't line up and the middle one is there. Mine has same issue.
    [​IMG]iii
    [​IMG][/QUOTE]
    hubedobeedo likes this.
  9. mk3ricks
    mk3ricks New Member
    Apr 4, 2018
  10. smokeatr23
    211
    Dec 24, 2014
    United States
