Sandblast gun recommendations?
Discussion in 'Garages, Workshops & Tools' started by arick793, Jan 9, 2016.
  1. arick793
    arick793 Veteran Member
    1,117
    Oct 27, 2008
    Rochester, NY
    I bought a used sandblasting cabinet, and the performance is a little weak... I'm thinking a higher quality gun might help? Also, what is a good air pressure to set the regulator to? Got any other tips? I'm using sand, and I also have bead blast media, it sucks with both. thanks!
  2. 71flh
    71flh Veteran Member
    936
    20
    Jun 1, 2010
    DFW
    I think the air system is more important.
    Can you describe what you have now? Telling you to go buy more stuff seems unproductive.
    Do you have 15CFM of clean, cool, dry air @100+PSI? You need air to blast...
    Describe the compressor, air system, and sizing.
    As far as pressure, as high as the system can handle. Blasting is shooting small rocks at something. Faster rocks knock the something off better.
  3. hot72rod
    Good advise 71flh.
  4. 351maverick
    351maverick Veteran Member
    3,260
    225
    Aug 11, 2010
    erie, PA
    higher pressure just destroys tips faster
    my Snap On cabinet clearly says do not exceed 80psi...my regulator is set at 70psi
    the BEST investment I ever made was a carbide blasting tip - I used to make tips at work from tool steel, but they would only last 30 hours before they wore out
  5. hot72rod
    351maverick im not sure that is completely true with all tips. I bought my cabinet some 15 years ago with an extra pack of tip. I have alway run my pressure at 120. Now my cabinet came with ceramic tips. Over the years I have run mainly sand. For about a year I did use glass bead. Only untill about a month ago I had only used those first 3 tips. I was haveing trouble fiding tips that would fit in my gun. I had some metal tips that would fit in another gun I have, so I swapped guns around. The 2 extra tip I had for that gun didn't last a week, luckily I had seen tractory supply had the tips I need. Also let me add in the last year I have been using black buil. What im getting at evey gun is different, it like pain guns you have to play with the pressure to see what it likes.
  6. Johnny Blaze
    Johnny Blaze Veteran Member
    911
    21
    Jan 24, 2013
    New Washington, IN
    Yep, it's all about the cfm
  7. buildinmy73
    buildinmy73 Veteran Member
    1,032
    Oct 20, 2007
    Bernardston, MA
    Also depends on what your blasting . If you blasting scaly rust gonna have to bump up the psi and run black beauty . if blasting something more fragile then glass bead at low psi.
    I agree sandblasting takes a ton of CFM . On big jobs iv'e even linked multiple compressors together and messed around with the "kick on & kick off" psi settings so they work together.
  8. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
  9. Happy_Dan
    Happy_Dan Veteran Member
    687
    95
    Sep 13, 2013
    New Boston, NH
    I uses TPT Tools stuff and bought my cabinet from them.
    When I use glass bead, I use 80CFM.
    If I try black diamond medium at that pressure, it won't pass through very well. I am at 100PSI for the medium black diamond.
    Ceramic tips seem to last pretty well.
  10. arick793
    1,117
    Oct 27, 2008
    Rochester, NY
    Those high flow fittings seem like a good idea, I'll have to look into that. Right now I'm just using sand in the cabinet. It works great on old paint, but struggles to remove rust.
