Rustover's 72 Camaro
Discussion in 'Project Progress' started by Double R Restorations, Nov 3, 2013.
  1. Double R Restorations
    2,617
    22
    Jan 11, 2002
    VA
  2. seventy7camaro
    seventy7camaro Veteran Member Lifetime Gold Member
    Thanks 80sz
  3. Double R Restorations
    2,617
    22
    Jan 11, 2002
    VA
    Not much progress lately. I have been working on the garage. I did take the time to compare an nos skin with a repro that I had in the garage. Here are a few of my findings:
    Nos Skin:[​IMG]
    Repro Skin: [​IMG]
    Here are some differences of the fold at the top of the skin where it welds to the frame.
    Nos Skin: [​IMG]
    Repro Skin : [​IMG]
    Some differences in the profile where it meets the fender:
    Nos Skin: [​IMG]
    Repro: [​IMG]
    Some differences in the flange width and the way the flanges were folded:
    Nos Bottom: [​IMG]
    Repro : [​IMG]
    Overall the repro is a nice piece and with a little work, it will work fine. You can see the video here.
    Zulu28 and Carolina Man like this.
  4. Carolina Man
    Carolina Man Member
    59
    Mar 18, 2017
    OK
  5. Double R Restorations
    2,617
    22
    Jan 11, 2002
    VA
  6. Double R Restorations
    2,617
    22
    Jan 11, 2002
    VA
    I finally started to prep the passenger door skin to install on the frame. I decided to use the Trim stud screws. I used them with 3m panel bond. I placed the panel bond between the two layers of the top of the door skin. I also placed the panel bond on the freshly blasted and cleaned trim studs. Hopefully they will not loosen up over time. I test fitted the molding clips several times along the way. I cut the screws down some on the back of the door skin so that they would not interfere with the door frame. After drying overnight I sanded them one final time, cleaned, and applied some SPI epoxy primer. I really wanted to use the molding rivets with my stud gun, but just could not get them to hold to my satisfaction. Hopefully the screws will work ok. Here are some pics:
    Thanks for checking my progress, Watch the complete video here, also don't forget to subscribe. Thanks, Russ
    Carolina Man likes this.
  7. Carolina Man
    Carolina Man Member
    59
    Mar 18, 2017
    OK
    I watched it and wonder how long the panel bond will last?
  8. Double R Restorations
    2,617
    22
    Jan 11, 2002
    VA
    Cliff, I'm not sure. That panel bond sets up really good. We shall see.
  9. Double R Restorations
    2,617
    22
    Jan 11, 2002
    VA
    So I got the passenger side door skin and door shell ready to go. I started working on the drivers side and I noticed the skin didn't fit that well. I knew the door had been in an accident and I thought the shell was ok. Turns out I missed it.
    My door shell
    Donor part
    Original damage
    [​IMG][/URL
    Watch the vid here:
  10. Carolina Man
    Carolina Man Member
    59
    Mar 18, 2017
    OK
    Knowing how good of work you do it will be seamless
