Rust prevention / undercoating
Discussion in 'Tips 'n' Tricks Topic' started by 80sz, Dec 9, 2015.
  1. 80sz
    80sz Veteran Member
    2,780
    288
    Feb 2, 2014
    Buffalo,n.y.
    Are u serious about the crisco? That is what I'm thinking,cheap and car wash takes it right back off ,and I also thought WD-40 . What's the process ,heat up and squirt on ? The undercoating shops here want 400.00 dollars,seems high,there is a fluid film sprayer in area ,haven't talked to them yet.
  2. CorkyE
    9,536
    265
    This, on both points.
    When I installed new steering components, I didn't want to paint them so I shot them down with Fluid Film. It's done a great job so far.
  3. bourbon_scotch
    2,105
    66
    Jan 10, 2003
    USA
    No of course not :D just a joke. I know in the old days my dad and uncle both use to spray oil in their doors to try to keep them from rusting. I guess you gotta do what you gotta do.
  4. CamarosRus
    CamarosRus Veteran Member
    FLUID FILM Sprayer in area ????
    FLUID FILM is not applied like a truck bed liner such as RINOLINER !!!!!!!
    FLUID FILM is an excellent rust inhibiting product that comes in aeresol cans or GALLON cans and is applied by the end user.
    "FLUID FILM is formulated from specially processed wool-wax, highly refined petroleum oils and selected agents to provide corrosion control, penetration, metal wetting and water displacement.
    These long lasting products contain no solvents, will not dry out and will penetrate to the base of all metals, providing corrosion protection from both natural and industrial atmospheres.
    Heavily corroded and/or frozen parts such as nuts, bolts, shafts, etc. that would normally be damaged during maintenance, can be salvaged by applying FLUID FILM."
  5. Twisted_Metal
    25,991
    507
    I've found that natural SBC fluid seepage works quite well!
    As long as it's covered with transmission fluid, motor oil or gear lube.... It doesn't rust! :D
    So... Why did I spend all that time cleaning the underbody and fixing those leaks. :confused:
  6. CorkyE
    9,536
    265
    lol Terry, that's so true.
  7. 80sz
    80sz Veteran Member
    2,780
    288
    Feb 2, 2014
    Buffalo,n.y.
    This is no classic camaro I'm driving in snow,its a 2002 base automatic v-6 with low miles,was someone's summer car. I can't afford new one so this is next best thing. I found a local shop that does fluid film,90.00 dollars for a car,I'm getting it done next week,then I'm getting some dedicated snow tires,I'm debating if I should go studs on back but then no rotate
  8. perkalator
    perkalator Veteran Member
    951
    57
    Aug 27, 2014
    kennewick wa
    Studs will be required, used to own a 1994 v6 camaro. It would go sideways just thinking about snow or rain. Fun little car and missed. It was my wifes favorite car or a tie with the wrangler. She cried when we traded it in for our first family car.
  9. hogg
    hogg Veteran Member
    3,150
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    w d 40 was made for the Army years and years ago,
    is formulated from specially processed, highly refined petroleum oils and selected agents to provide corrosion control, penetration, metal wetting and water displacement.
    Heavily corroded and/or frozen parts such as nuts, bolts, shafts, etc. that would normally be damaged during maintenance, can be salvaged by applying w d 40 ,,still works for some stuff,,,,,,may be hard on paint and rubber,plastic
  10. COPO
    16,519
    301
