Running lean or okay
Discussion in 'High Performance Modifications' started by harkz28, Nov 23, 2017.
  1. harkz28
    harkz28 New Member
    15
    Aug 22, 2005
    'm going to attach a picture of some spark plugs can you tell me if I'm running too lean or okay. 20171123_085510.jpg
  2. COPO
    16,276
    245
    On the lean side. I can’t make out the color
    on the bend. When timing is correct the color change
    will be at the bend.
  3. larrylarry
    larrylarry Veteran Member
    1,453
    55
    Dec 22, 2011
    San Antonio Tx
    Doesn't seem to be really lean otherwise they'd be bone white, being rich is better than being lean but neither is correct. FYI a performances built engine likes being rich or needs to be rich to run well.
  4. Dave Nelson
    3,429
    682
    Dec 19, 2003
    Vineland N.J USA
    Can you post a side shot of the ground straps?
  5. COPO
    16,276
    245
    Should look something like this.
  6. muscl car
    Post a close up pic of the ground strap ant the bend !!!
  7. muscl car
    RS1979 likes this.
  8. 77 cruiser
    77 cruiser Veteran Member
    475
    14
    Nov 17, 2006
    Frostbite Falls MN
    If that isn't after a WOT run & shut off clean it won't tell much.
    If it's after just cruising it's fine.
