Road Course Fun
Discussion in 'Track Day, Solo, AutoX & Sanctioned Road Racing' started by Bill70, Aug 15, 2016.
  1. Bill70
    Bill70 Veteran Member
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    The front is 700# Moog springs, GW uppers w/tall balljoints, Viking shocks, and Hotchkis hollow bar. I also added a quick ratio steering box. Rear is Speedtech 3 link with a 9" rear and floater axles/hubs, Ridetech coilovers. Willwood brakes front and rear. It's mostly bolt in stuff and it works.
  2. RS1979
    3,220
    461
    Jun 18, 2013
    Memphis, TN
    The corners looked tough for you; but, you dominated the straightaway.
  3. Bill70
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    Thank you. It's bare bones except I added power windows.. I figured I can't reach the window crank in a 5 point harness.
  4. APEowner
    APEowner Veteran Member
    646
    11
    Dec 9, 2013
    Albuquerque, NM
    Very nice. Beautiful car. What steering box are you running and what's the steering effort and road feel like? I've got what's supposed to be the WS6 box in my car and it feels over boosted and numb.
  5. Bill70
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    I'm using the Delphi 600 12.7 steering box with a KRC aluminum pump. Spoke with KRC a few times and they told me I needed to upgrade to their small volume pump ($$$) because the typical GM pump will overheat the fluid and cause problems. I researched this and sure enough a lot of people tracking their 4th gen Camaro's were having pump problems and were adding coolers with limited success. My engine turns 7000-7500 each lap and have never had a problem. No cooler needed in the Arizona heat. The steering effort is noticeable but very driveable. So much so that I called KRC to ask about a bigger flow valve for the pump. Tech guy talked me out of it and said I need to get all the air out. That seems to have worked.
  6. dale68z
    dale68z Veteran Member
    1,306
    May 14, 2009
    Glendale Arizona
    Nice job Bill. Will you be going to Inde on Labor day?
  7. Bill70
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    Hi Dale. Planning on going to Inde on Friday for the afternoon sessions and then stay overnight for Saturday.
  8. APEowner
    646
    11
    Dec 9, 2013
    Albuquerque, NM
    Thanks Bill. I'll check that option out.
  9. carr911
    carr911 Veteran Member
    1,183
    233
    Mar 4, 2016
    Tampa, FL
    Car looks beautiful!
    Course looks short, how long were your sessions?
  10. Bill70
    228
    9
    Jan 8, 2012
    Phoenix, AZ
    Thanks. The video was taken from one place on the track. I think the track is about 1.75 miles total. Sessions were 20 minutes each.
