Ridetech's new rear suspension
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Zulu28, Oct 29, 2017.
  1. badazz81z28
    14,637
    159
    Las Vegas, NV
    ^^ you guys need to be careful. If you want mini tubs and 335 tires some of theses system that use the oem leaf spring mount on the axle will not allow it. I almost bought this system years ago, looks easy to install
  2. Zulu28
    Zulu28 Veteran Member
    228
    16
    Dec 19, 2013
    Vancouver, BC
    Yes, that is evident on the T/A in the video, you can see the offset that was used which will work on the T/A but not a Camaro,
  3. carr911
    carr911 Veteran Member
    959
    202
    Mar 4, 2016
    Tampa, FL
    To do 335's you need to do the 9" Option which pushes the mounts inward.
