Reverse/lock steering linkage
Discussion in '1970 - 1973 Specific' started by ncarcamguy, Mar 17, 2017.
  1. ncarcamguy
    ncarcamguy New Member
    26
    Jan 27, 2017
    Hi there camaro world. Im working on a 70 r/s s/s. small block and Im trying to keep my steering lock when put in reverse .(4 speed)...AND use headers ....does anyone know of a way??? Cable maybe?? Thanks
  2. BonzoHansen
    My back rod linkage worked with my ST10 and hooker headers. I suppose the trick is the right headers.
  3. Green hornet
    Green hornet Veteran Member
    1,351
    203
    Oct 11, 2015
    North Bay, CA
  4. grzewnicki
    I used Hedman elite headers on my car and kept my back drive linkage working no problem.
  5. Gary S
    21,334
    374
    The right headers will not interfere with the backdrive linkage. I've had 3 different brands of headers on my Camaro in the last 40 years and none of them got in the way of the backdrive linkage. Properly designed parts will fit.
    Buy your headers locally with the guarantee that they fit. If they don't, take them back for a refund or replacement of a better brand.
  6. Green hornet
    1,351
    203
    Oct 11, 2015
    North Bay, CA
    I also used Hedman elite headers. Based on the research I did here and the recommendation of other members. They fit great and no issues with having to use shorter spark plugs or spark plug wire boots touching the tubes. Still had a little interference with the back drive that's why I fabed my own linkage.
  7. 70-camaro
    70-camaro Veteran Member
    1,626
    262
    Mar 25, 2010
    marietta ohio
    I don't have a back drive linkage for the TH 350 in my Camaro. Maybe I should take a chance and buy one.
  8. ncarcamguy
    26
    Jan 27, 2017
    Ii was told the bell crank on the frame is the problem..not so much the rod...???
  9. ncarcamguy
    26
    Jan 27, 2017
    Thanks to all for the great info. Will try the HEADMAN brand. ✌
