Replacing oil pan gasket 1979 Z (350)
Discussion in 'Tips 'n' Tricks Topic' started by GPN, May 8, 2017.
  1. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    big job or small? In other words, have to lift motor ect, or is it just a matter of removing bolts & dropping from below?
  2. Zspoiler
    Zspoiler Veteran Member
    2,813
    173
    May 6, 2012
    Federal Way, Washington
    Take the engine out .Its a lot less hassle.And I use a Fel Pro oil pan gasket.It spares your knuckles as well 130044932860518017_26257430996_o (1).jpg
  3. Green hornet
    Green hornet Veteran Member
    1,396
    209
    Oct 11, 2015
    North Bay, CA
    It can be done in the car. I and others have done it. You have to lift the engine enough to put some 2x4 spacers between the engine mounts and the frame. Next you have to turn the crank in the correct position (that position escapes me at the moment) so that the journal are in the correct position. The pan can then be slipped out. Do a search here and you will find info on it.
  4. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Tnx
  5. cadillac_al
    cadillac_al Veteran Member
    683
    46
    Apr 22, 2015
    Maine
    I hate doing it in the car so much that I would take the engine out and detail it and maybe repaint it.
  6. Bandit723
    Bandit723 Veteran Member
    2,692
    328
    Oct 1, 2016
    Waupaca WI
    Like other folks have mentioned it is a bit of a pain to do with the engine in the car. I believe if you set your timing marks on the balancer to 5-6 o'clock position you will have clearance to pull the pan. I would pull the engine to do this right also may want to consider replacing the rear crank seal while this is out as well.
  7. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    All good points thank you
  8. GPN
    GPN Veteran Member
    135
    Oct 5, 2016
    Got it, tnx
