Replacing 1981 Z28 Air Conditioning?
Discussion in '1978 - 1981 Specific' started by Zebus28, Dec 13, 2017.
  1. Zebus28
    Zebus28 Member
    33
    May 6, 2001
    Effort, PA, USA
    I have a 1981 Z28 4 speed with factory air. The compressor broke many years ago, the clutch pulley seized. I cut the belt and left everything intact.
    My question. I want to get the A/C working again, do I simply replace the compressor and charge the system or since it has been out of commission for so long, do I need to do more. What about the refrigerant, do I need to also convert to R134? If so how do does this work?
  2. wnmech
    wnmech Veteran Member
    809
    53
    Jul 20, 2014
    grand prairie tx.
    If it were me I would flush out the whole system and replace the in line orifice tube and the accumulator along with all the O rings with R134 compatible O O rings and make sure the hoses are pretty good shape. If you are going with R134 you wont get the cooling that you had with the R12 especially at idle. I don't know what the availability of R12 is in your area but I have found it here at swap meets and craigslist for $10-15 dollars a can. There's not as much demand for it now and people are selling it cheap.
  3. Zebus28
    Zebus28 Member
    33
    May 6, 2001
    Effort, PA, USA
    Thanks. Sounds like a good approach given the system has been "dry" for so long. Is this a diy job or should I have an A/C guy look at it?
  4. 8pack
    2,390
    72
    Aug 29, 2007
    Pittsburgh, PA
    I am in Pittsburgh which is pretty far from you but I have a basically new compressor A6 with new hoses I took off my car when I swapped to a serpentine system. You can have it if you like but it will probable be expensive to ship unless you have a corporate account and get discounted rates.
    When I swapped to my serpentine system I kept the factory air system except I had to run new lines and a new Sanden Compressor. I got it from Classic Auto Air. They have a kit for it. If you have the cash I highly recommend swapping to a serpentine system. It moves the compressor to the passenger side and alternator to the drivers side. You have to get a reverse clutch fan and reverse water pump and some other things to make it work, but it was the best upgrade I have done so far.
    In terms of your question about it being a DIY job.....Since your system is already empty, you can hook everything up yourself but I would take it to a shop to get it charged. I am sure there will be folks on here who will explain how to do it yourself but you need to rent the tools to pull a vacuum on it and then recharge it and I would rather have someone who does it all the time check my work and charge the system.
  5. Zebus28
    Zebus28 Member
    33
    May 6, 2001
    Effort, PA, USA
    That sounds awesome. I assume it was working fine when you took it off right? I do have a shipping discount with UPS, how much do you think the whole system weighs? I can get an estimated shipping cost if I know the weight.
  6. 8pack
    2,390
    72
    Aug 29, 2007
    Pittsburgh, PA
    I will go up in the attic and look today. A good 30# ++ is my guess. Maybe someone on here knows the actual weight.
  7. Zebus28
    Zebus28 Member
    33
    May 6, 2001
    Effort, PA, USA
    I can check with UPS on the shipping charge if you give me an address the shipment would come from. I'm thinking it can't be anymore that a whole new A/C system.
