Replacement turn signal switch from NPD.
Discussion in '1970 - 1973 Specific' started by CAM aro - 1970, Jun 8, 2017.
  1. CAM aro - 1970
    CAM aro - 1970 Member
    33
    Feb 26, 2009
    windsor, ontario
    I may have to replace my turn signal switch. I have a 70' with console shift. My question is: I looked at the replacement switch in the catalogue, and it has the switch, but beside it, is some sort of "adapter" that has to be used in order to make the AC Delco turn signal switch fit the pins of what it plugs into. There is a "note" at the bottom of the description for this adapter. I'm wondering if another company has the proper turn signal switch, that I don't need to buy this adapter. Anyone run into this issue. Thanks, Cam.
