Repair scratch glass window in my office
Discussion in 'Tips 'n' Tricks Topic' started by ilamiesmie, Feb 5, 2017.
  1. ilamiesmie
    ilamiesmie New Member
    Feb 5, 2017
    Hi ,
    Need helps here in removing scratch on this glass ,do try braaso but not really effective ,any advise please .
  2. budro6968
    budro6968 Veteran Member
    2,539
    344
    Apr 2, 2016
    Jax Florida
    Try using a buffer with compound. I have taken light scratches out of windshields before. If they are too deep then you can't get them without heavy grit and a lot of patience. I watched windshield repair guys on car lots buffing glass. They only try the light stuff because it takes a long time to do deep ones. They just replace in that situation.
  3. dcozzi
    dcozzi Veteran Member
    2,261
    55
    May 1, 2002
    Phoenix, AZ
    I've used toothpaste and a little water before to get rid of marks from the window guides on the door glass.
  4. ilamiesmie
    Feb 5, 2017
    Means that ,only using simple tool to remove the scratch
  5. fester
    fester Veteran Member
    132
    9
    Jun 26, 2016
    Central Texas
    Headlight restoring kit, made for hard plastic but you can use the polishing portion of it..
    ilamiesmie likes this.
  6. daustin
    daustin Veteran Member
    260
    Jul 29, 2009
    Woodstock, GA
    Buffer with some baking soda and water mix.
    Don
