Refinishing hood hinges.
Discussion in 'Camaro Questions' started by Blu-By-U 79Z, Oct 3, 2016.
  1. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,542
    15
    Feb 11, 2009
    Kentucky
    So I cleaned up a set of hood hinges to bare metal. Then did some etch primer and satin black rustoleum paint hoping that it would not build so much that it wore the paint off. Well it looks like I was wrong SO.... im wondering how in the world can you refinish the hinges and avoid the paint getting rubbed off? Thanks
  2. 70lt1z28
    2,549
    374
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I don't know about '79's, but the early '70's didn't paint them they were plated with zinc phosphate which didn't rub off.
    Other than that, maybe powder coat is tough enough.
    Blu-By-U 79Z likes this.
  3. Blu-By-U 79Z
    5,542
    15
    Feb 11, 2009
    Kentucky
    I wish i knew if they still made something that would treat them like factory did.
  4. BonzoHansen
    i don't think you can avoid paint wear on them
  5. slayer021175666
    slayer021175666 Veteran Member
    1,213
    57
    Feb 29, 2016
    Idaho
    If you paint them, They WILL ALWAYS wear a bit where the movement rubs. There is no avoiding it. I have found however, that the thinner you can make the paint coat, the lighter the wear! I never prime hinges. Sand blast and paint only. Paint as thin as possible to get full coverage especially at places of movement. Also, use lithium on the surfaces that rub together! These points are EASY to find on newly painted hinges. Close the hood for the first time and re-open it. Might want to do this 3 or 4 times. Grease the places that show rubbing marks. :)
  6. CamarosRus
    CamarosRus Veteran Member
    Zinc Phosphate with a Rust Preventative Oil Coating
    like FLUID FILM or BOESHIELD T-9
  7. 70lt1z28
    2,549
    374
    Oct 3, 1999
    Palmetto Enterprises in Georgia sells the zinc phosphate chemicals. You need to glass bead them and then submerge in a 200F heated tank for 10-15 minutes. Remove and quickly spray with WD40 or Fluid Film. I have a stainless steel sink on a propane grill that works good for this.
  8. 70 SS/L78
    2,573
    63
    May 5, 2005
    Rockford, MN
    You can still get your hinges re-plated like they were originally from the factory. I've hear the Palmetto stuff works pretty good but never used it personally.. If you would rather not do the replating yourself then look for a plating shop in your area. Brakeboosters.com in California specializes in replating automotive parts in several types of finishes.
    flint9 and Blu-By-U 79Z like this.
  9. TommyRS70
    TommyRS70 Veteran Member
    922
    23
    Jan 31, 2004
    KY
  10. zekefreak
    zekefreak Veteran Member Lifetime Gold Member
    1,541
    11
    Apr 16, 2006
    western PA
    Where would one find the manganese and zinc parkerizing solution found in the video? Very interesting way to coat nuts and bolts.
    74Z28GC3 likes this.
